Transmission ID
Old Jan 5, 2013 | 09:32 AM
smife's Avatar
smife
Transmission ID
I have a 1997 Ford Expedition. The tranny was replaced a few years ago. I am trying to find out what tranny is in my vehicle. The ID codes on the tag are as follows:
A287 3 4406-17
154523 F75A-CC
Also I found the following on the Bell Housing:
RF-F2TP-7A040-BA
I cannot find any other tags or info anywhere.
Thanks;
Smife
Old Jan 5, 2013 | 11:49 AM
alloro's Avatar
alloro
RF-F2TP-7A040-BA
That part number is for an AOD-E transmission.
Also:
AOD-E = 14 pan bolt holes.
E4OD = 20 pan bolt holes.
Old Jan 5, 2013 | 11:50 AM
r2millers's Avatar
r2millers
A287 3 4406-17
154523 F75A-CC
RF-F2TP-7A040-BA
Thanks;
Smife
No sure any of those #'s are pertinent. If it's a 5.4l w/auto it's probably a E40D/4R100.
Old Jan 5, 2013 | 10:00 PM
pdqford's Avatar
pdqford
Okay. So far all we know is that your Expy is a 1997. It would be helpful to know what engine you have. The eighth digit of your VIN will tell the engine in your truck. In 1997 a "6" is a 4.6L Windsor engine, "W" is a 4.6 Romeo engine, and a "L" is the 5.4L. (Hint - the make, model and year of your vehicle in your sig line and add the eighth digit of your VIN to your sig file then we will never have to guess what engine you have.)
You can look at the last line of your Vehicle Cert tag on the driver door post. There will be a single character under the TR (for transmission) and will be the code for the type of transmission in your vehicle. Tell us the code and someone will be able to look it up for you.
Old Jan 6, 2013 | 12:55 PM
alloro's Avatar
alloro
The tranny was replaced and is not original. He's trying to verify which tranny was installed as the replacement. Original codes or the VIN will not help in his situation.
Old Jan 6, 2013 | 07:43 PM
pdqford's Avatar
pdqford
Your r-r-r-right. I was "asuming" it was replaced with the same type as original (4R70W or E4OD).
Old Jan 7, 2013 | 10:21 AM
alloro's Avatar
alloro
I was "assuming" it was replaced with the same type as original
One would like to ***/u/me so. But there are those out there that don't always do things the right way.
njxlt
Dec 4, 2023 02:13 PM
Cjpower9185
Apr 5, 2017 06:34 AM
smife
Jan 5, 2013 02:21 PM
86scotty
Sep 17, 2011 04:43 PM
SBastow
Jun 12, 2008 02:11 PM
