No electronic shift
Old Jan 16, 2004 | 12:39 PM
Alby's Avatar
Alby
No electronic shift
I have a 93 F150,302 , E4OD. I recently did a motor swap as a connecting rod went through my oilpan due to an oil pump failure. While I was at it I had my tranny rebuilt added a shift improvement kit and new torque converter. Engine runs great shifts super. Only problem is no electronic shift for the transfer case, won't even light up on the dash. I checked my connections, shift motor was taken out and checked out. Electronic shift control module checks out per the Ford dealers instructions, check light blinks four times. I can shift it with the shift motor off manually so I think the transfer case is okay. Any ideas out there?
dtherrien
1997 - 2003 F150
Oct 19, 2014 04:09 PM
lawnboy58
Bronco II
Jan 3, 2008 12:08 PM
todd34
Jan 18, 2006 08:22 PM
