Wiring for steering column
Old Jan 16, 2004 | 10:12 AM
73'BiGrEd's Avatar
73'BiGrEd
Lightbulb electricle
hi, i have a 73' factory high-boy and im haveing some wireing problems. i had to replace the steering collum harness because it was fried and my blinkers didn't work. after i got the new one in, my blinkers worked for about a week and then they quit and i cand figure out why. ive checked the fuses and still cant find whats wrong with it. anybody have any ideas?
Old Jan 16, 2004 | 10:37 AM
76supercab2's Avatar
76supercab2
My first suggestion would be to take it to a good automotive electrical shop.
Secondly you might try the 73-79 forum further down the page.
Old Jan 16, 2004 | 07:15 PM
sparky's Avatar
sparky
Have you tried a new flasher unit? You can swap the one from the emergency flashers for testing...that is if they work.
Old Jan 16, 2004 | 09:46 PM
Franklin2's Avatar
Franklin2
Are they totally dark, or do they come on but don't blink? Are the fronts working and the rear ones not working? Do the brake lights work?
Old Jan 20, 2004 | 10:07 AM
73'BiGrEd's Avatar
73'BiGrEd
the flashers work but the blinkers do not work at all, and i dont think i'm getting power from my fuse block
Old Jan 20, 2004 | 12:10 PM
Mil1ion's Avatar
Mil1ion
What do you mean by Blinkers ?
Please specify exactly what you have in a specifc terminology.
As in:
Front Turn signal lights
Rear turn signal lights
Indicator lights on the instrument cluster
Hazard lights Front
Hazard lights Rear
Brake lights
Old Jan 20, 2004 | 01:18 PM
Franklin2's Avatar
Franklin2
The turnsignal switch/column area is rather complex, with several different circuits mixed in. That's why we need specific info on what exactly is working, and what is not. If you give us all this info, we might be able to pin-point the possible problem area.
If you hear the flasher clicking under the dash, you have power to the flasher.
Old Jan 21, 2004 | 05:54 PM
73'BiGrEd's Avatar
73'BiGrEd
The Front & Rear hazards light work,
The parking lights front and rear work,
The driver's side brake light works
The passenger brake light side does not work.
The indicator lights on the dash do not work as direction lights
but, they do come on when my hazard lights are on.
So,
No Turn signal lights with with lever
No indicator lights with lever
No right brake light.
Old Jan 21, 2004 | 07:51 PM
Mil1ion's Avatar
Mil1ion
Okay, I edited your post to help us pinpoint the problem.
You need to check your Turn signal flasher.
The fact that all the hazard lights work tells us the bulbs are good.
I think this is mostly related to the turn signal switch.
Franklin will explain the process to check it.
Won't you Franklin ?
Old Jan 21, 2004 | 09:17 PM
Franklin2's Avatar
Franklin2
I don't have a diagram for a 73 to get the wire colors to help you test. But it sounds like the turnsignal switch is bad.
Let's focus on the brake light that does not work.
Find the color of the wire that leaves the brake light switch. This wire will be sending power from the brake switch, to the turn signal switch.
When the turn signal switch is in the middle position, the brake switch power is fed into the turnsignal switch, and then out to the two seperate wires feeding each brake light. If you have a diagram, you will know what the colors of the wires are leaving the turn switch, and you can test them for voltage at the column.
With the turnsignal switch in the middle position, and the brake pedal depressed, you should have 12 volts on both wires leaving the switch, going to the brake lights.
If you find you are lacking voltage on one of the brake light wires, you might want to wiggle the lever a little bit to see if you get voltage. You may also want to check your connectors in the column, if you get voltage out of the switch, but not in the rest of the harness going to the rear.
Old Jan 22, 2004 | 12:36 PM
73'BiGrEd's Avatar
73'BiGrEd
my turn signal flasher is good but i'll check the other stuff. Thanks for your help all let you guys know if i get it fixed and or what i find out
Old Jan 22, 2004 | 12:48 PM
Mil1ion's Avatar
Mil1ion
You know that there are 2 flashers/relays..... correct?
One for the hazards & One for the T/signals
Old Feb 12, 2004 | 09:52 AM
73'BiGrEd's Avatar
73'BiGrEd
yeah i know there are 2 flasher relays. i havent worked on it much because im in school during the day and when i'm not in school i'm working but i'm going to work on it today for a bit
