Oil & Lubrication
synthetic VS. oil
Old Jan 16, 2004 | 07:54 AM
UncleJesse's Avatar
UncleJesse
synthetic VS. oil
Anyone seen any great differences(besides cost), in synthetic oil? After reassymbly of my 351M I am considering using synthetic. And will the rings seat using synthetic or should I use reg. oil until their seated and then change? Thanks Uncle Jesse
Old Jan 16, 2004 | 09:10 AM
jimandmandy's Avatar
jimandmandy
While I do not think synthetic is worth the extra cost, especially in a truck, this ring seating thing is a throwback to the old chrome-plated rings of the past. Unless you used chromed rings, break in oil should not be an issue. Some new cars, Corvette, BMW, Mercedes and others, leave the factory today with synthetic already in there, so it cant be an issue.
Some folks do like to use a cheap oil for initial fill and then dump it within a short time to flush out any dirt or other particles that may have been left behind during assembly, probably overkill.
Rebuilt aircraft engines use non-detergent mineral oil for initial fill because of the chromed bores.
Jim
Old Jan 16, 2004 | 12:08 PM
jessfactor's Avatar
jessfactor
do a search on this topic. there have been many endless threads.
Old Jan 16, 2004 | 04:08 PM
c_rossman's Avatar
c_rossman
The only reason I like synthetic is that when it is -30 degrees it still flows like water. Atleast the older mobil 1 try-synthetic. I guess the new supersyn isnt as good for cold weather.
Old Jan 17, 2004 | 06:47 AM
mustangsvt's Avatar
mustangsvt
No its not as good for cold weather. i started up my car yesterday morning it was -1 degrees. Started perfectly but took a heck of a while to warm up. Still sounds a lot better than my parents cars
Old Jan 17, 2004 | 11:04 AM
daerhldgs2's Avatar
daerhldgs2
I use 5-50 Castrol Syntec year round and if you finish your cyl walls to a 320 or 400 grit you can put in cast or moly rings and synthetic immmediately and you shouldn't use oil . I always run a cheap oil for the first 30-45 minutes and drain it and change the filter on a new motor at first start up as there is always minute bits floating around in the engine after a overhaul.
Old Feb 1, 2004 | 11:38 AM
Eddie Buxter's Avatar
Eddie Buxter
I went to 5-40 Rotella Syn. oil after previous owner ran truck 42K with dino. I am sold on synthetic because of observations I have made in the industrial world documenting before and after results going from dino to syn on large (200hp) air compressors. Not exactly apples to apples but I have seen significant drops in heat and vibration with synthetic which I have documented. I want the best for my '02 PSD so wouldn't use anything else.
Old Feb 1, 2004 | 01:03 PM
2fords2's Avatar
2fords2
I don't think there is any easy answer to your question. IM view, synthetics cost more and on the basis of uoa alone, do not generate lower engine wear than dino oil. They do offer the advantage of using extended drains if you are so inclined, improved engine cleanliness, are better where turbos are used, towing or other temperature extremes. In the final analysis it is a personal choice based on your driving conditions and maintenance preferences.
Old Feb 1, 2004 | 01:13 PM
Eddie Buxter
Well stated, 2fords2. I'm new- what is uoa?
Old Feb 1, 2004 | 04:29 PM
2fords2's Avatar
2fords2
uao is short for used oil analysis. It is a laboratory report about the condition of used automotive oil, including the key metals that typically show wear in an engine, among other important readings. Cost anywhere from $20-35. You'll see a few reported on this site. Or go here if you really want to over dose on the topic .....
http://theoildrop.server101.com/ubb/...?ubb=forum;f=3
r-kid
Apr 27, 2013 08:25 PM
lakewood
Dec 15, 2009 01:59 PM
joe welder
Nov 4, 2009 09:02 PM
NCF150
1997 - 2003 F150
Dec 30, 2003 10:04 AM
trhea6922
Oil & Lubrication
Apr 5, 2002 01:43 PM
