Oxygen sensor?
Old Jan 15, 2004 | 11:11 PM
carpe_diem's Avatar
carpe_diem
Oxygen sensor?
This is on 89 F250.
where is it located?
I hear that it needs to be changed every 80,000 miles, as it gets 'lazy' and your mpg worsens. Although I haven't really experienced that. It is F250HD, with 7.5cid/4.10 rear, which is not designed for mileage to say the least. I get 7-8 in the city and up to 11 on the highway if I keep it under 3,000.
Any O2 sensor stories?
Old Jan 15, 2004 | 11:19 PM
LxMan1's Avatar
LxMan1
Most of that era of truck, I have seen them located in the short crossover pipe just before the cat. converter.
Jimmy
Old Jan 15, 2004 | 11:33 PM
carpe_diem's Avatar
carpe_diem
How do you access it, from under the truck?
Old Jan 17, 2004 | 12:42 AM
LxMan1's Avatar
LxMan1
Yess, on the passenger side. There is usually a short piece of pipe between where the 2 pipes go into the cat. converter. It is kind of "H" shaped.
It will be in the pipe connected in between the two pipes. A 7/8" wrench will usually take it out.
Jimmy
Old Jan 18, 2004 | 11:27 PM
carpe_diem's Avatar
carpe_diem
At what mileage do you typically replace it?
Old Jan 20, 2004 | 03:59 AM
bob arrington's Avatar
bob arrington
its been my experience that when the cat goes bad , its a good idea to replace the o2 also. i have never heard of a set milage for them, the slow reaction is usually caused by a cat that is starting o plug.there are other reasons of course , you can slso test th with a50.00 tester from a parts store, good luck,bob
Old Jan 20, 2004 | 05:38 AM
LxMan1's Avatar
LxMan1
They should be replaced every 60,000 miles. Over time, carbon builds up in them causing them to not read properly.
