Sponsored by: Real Truck
Need photos
Old Jan 15, 2004 | 06:37 PM
Orlie's Avatar
Orlie
Need photos
I am putting a 4" pro comp lift on my 00 SD CC, I just ordered my tires and wheels, and was wondering if any one can post some pictures of a 250 or 350 with a 4" lift. More the better.
later
Orlie
Old Jan 15, 2004 | 06:41 PM
Yeti's Avatar
Yeti
Im not sure who has a 4", but someone will be along shortly, Im sure.
Old Jan 15, 2004 | 06:48 PM
DCSpecial's Avatar
DCSpecial
4" with 35s:
Old Jan 15, 2004 | 07:23 PM
cwb's Avatar
cwb
Hey there Mr. Special-when you gonna put on that big lift?
Old Jan 15, 2004 | 07:30 PM
DCSpecial's Avatar
DCSpecial
As soon as I stop spending money on other things
Old Jan 15, 2004 | 07:51 PM
cwb's Avatar
cwb
Huh! I heeeaaard that!
Old Jan 15, 2004 | 08:02 PM
Orlie's Avatar
Orlie
DCSpecial,
How many inches did it raise the truck with lift and tires together.
later
Orlie
Old Jan 15, 2004 | 08:10 PM
DCSpecial's Avatar
DCSpecial
4" out of the lift and about 1.5" out of the tires so probably around 5.5" total up front.
Hope this helps.
Old Jan 15, 2004 | 10:07 PM
Tim Houston's Avatar
Tim Houston
King Ranch with a 4"
Here is my lastest Baby!
I would stay away from the ProComp for Super Duty Diesels as the springs do not hold up in the front. They tend to sag quickly and the lift is lower than a SkyJacker or SuperLift. I've had all three and the Superlift is by far the softest ride and tallest of the 4" series.
A lot of cutting on the tubs was needed for the Nitto's as they are wide and square. BFG's 35 should work fine with little cutting. A lot of cutting with the Procomp 4".
Go for new rear springs if you can swing the extra $350.00 or so for the best ride. The add-a-leafs will be extremly tight in the rear.
http://www.timlassiter.com/kingranch.htm
Old Jan 15, 2004 | 10:35 PM
Yeti's Avatar
Yeti
Tim...clean looking truck
Old Jan 16, 2004 | 12:30 AM
Tim Houston
Thanks, Yeti!
I went all out on this one! I wanted to go 6" but my customers already have a hard enough time getting into a 4".
I think the 18's are the hot ticket for 35 inchers!
Tim
Old Jan 16, 2004 | 03:58 AM
fitter565's Avatar
fitter565
Tim...AWWWWWWWSOME Truck!!
