Head Compatability
Old Jan 15, 2004 | 05:32 PM
justus07's Avatar
justus07
Lightbulb Head Compatability
I don't have a truck but I do have a Ford product. It is a 92 Mercury Grand Marquis with the 'w' VIN number. This is a 4.6L SOHC.
I was hoping I could get some info from you guys on other years that are compatible for swapping the heads.
If I can't find the heads maybe you guys might know what year engines would be a direct bolt in without modification.
I know you guys are experts so if you could share some of the knowledge you have on these engines I would appreciate it greatly.
CJ
Old Jan 15, 2004 | 10:34 PM
LxMan1's Avatar
LxMan1
I believe that any head off of a W 4.6L will work from 98 on back. I think that the Romeo 4.6 may have a different timing chain set-up, but the heads should be the same.
Jimmy
Old Jan 17, 2004 | 08:26 PM
JustinH's Avatar
JustinH
the early 2v heads have terrible air flow, so bad they aren't even worth porting.
The 96+ heads are excellent for porting.
Old Jan 19, 2004 | 12:15 AM
LxMan1's Avatar
LxMan1
99-up heads are the best. They have a PI stamped in them. I believe that the 98-back have 11 bolts in the V/C's and the 99-up (PI heads) have 13/14 bolts in them. That's what the BBK valvecover listing shows.
Jimmy
