Sponsored by: Real Truck
1997 460
Old Aug 3, 2002 | 10:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Old Aug 4, 2002 | 01:36 PM
WOLFBAYOU's Avatar
WOLFBAYOU
I have a 1997 F350 4.10LS w/ a 460 that I just recently had a 30' GN and 7000lbs of green oak on and it didn't seem to pull like it ought too, there was one hill that had a curve at the bottom so I had to slow down to 25 but it wouldn't pull the hill faster than 15 in second after the sharp curve, It is running perfect other than that no blowby,smoke,pinging, or anything.I AM getting a code that sais HEGR lean but what does that mean I have replaced O2,TPS,air,coil,cap,wires,plugs,cleaned TB, I DO have a slight driver side manifold leak that started right after I got the passenger side fixed and also dual 21/4" pipes with 20" glasspacks which I hate, can somebody make a logically explanation?
It also won't rev past 3500rpm in 3rd and it just feels weak when you downshift, it almost feels like it lugs better than downshifting,gaining rpm then upshifting again.
thanks
Joel Thomas 19yrs old
Wolf Bayou,AR
Certified Firefighter
