1988 Stock Tachometer
Old Jan 15, 2004 | 04:42 PM
parks911's Avatar
parks911
I curently have the instrument cluster without the tach.
I am buying a 1988 F-150 for parts that has the tach in the cluster.
My question is,
Will the 1988 cluster with the tach replace my 1988 cluster with-out the tach?
Do I have to swap the harnesses? Or are the harnesses the same with the leads already installed to hook the tach up?
Does those question make sense?
Old Jan 15, 2004 | 05:35 PM
mantta's Avatar
mantta
It is plug and play, all you need to do is put it in.
Old Jan 15, 2004 | 05:44 PM
parks911's Avatar
parks911
Hot damn!! That was the answer I was looking for!!
So the wiring harness plugs are there correct? Are they labeled so I know which is which?
Now I got to talk the man down a few hundred for this truck & I'll be good to go. He is wanting $700.00 for the truck complete with a bad front fuel pump & a leaking rear tank. (in other words the truck aint running)
I can use the bed, cab, drivers door, drivers fender, front fuel tank, & all the interior peices.
If I buy the truck, all the other good parts will be on eBay.
Old Jan 15, 2004 | 06:11 PM
broncobasher's Avatar
broncobasher
On the same note, I want to put a inst cluster w/ tach in my 1990 f150 auto. What vehicles/year models have the same cluster, F150 and maybe Ranger??
BroncoBasher
Old Jan 15, 2004 | 06:31 PM
mantta's Avatar
mantta
I think the 87-91 are all the same. You can not plug them in wrong, the plugs are not the same. Ranger clusters will not work on a F-150.
Old Jan 15, 2004 | 06:45 PM
carpe_diem's Avatar
carpe_diem
parts vehicles are great. Ebay is another good idea.
Especially keep the headlights, mirrors, things like that. I stupidly sold mine (for a parts car) and then needed them.
Old Jan 15, 2004 | 10:07 PM
frederic's Avatar
frederic
it only sucks when you buy a cluster in the junkyard, which looks exactly like your cluster plus the tach, only to realize your 93 F-series has a digital odometer, hence no speedo cable.
Its amazing how one can look at something every day for 10 years and not remember while wandering the yard LOL
