rattle/loose chain sound whith startup.
Old 01-15-2004, 04:18 PM
ExplorerSp0084's Avatar
ExplorerSp0084
ExplorerSp0084 is offline
I recently noticed my 2000 Expl. Sport 4.0L OHV has an odd sound after starting up. The sound is kinda like a chain rattling coming from somewhere towards the front and maybe underneath the vehicle. The noise is only present while in drive or reverse and goes away after the engine has warmed up. Anybody know what this could be Id like as much info as possible before it either gets worse or before I take it to a shop. Thanks guys.
Old 01-15-2004, 04:28 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Cam chain tensioners or guides!
Also how many miles on your ex ?
What oil and filter are you using?
Do you do your own oil changes ?
If so be aware of any white plastic pieces coming out of the drain plug.
these are from the cam tensioners and guides
Take it in.
Rich
Old 01-15-2004, 04:51 PM
ExplorerSp0084
have been doing my own oil changes the last 4 times or so never noticed anythign in there just changhed oil yesterday and nothing. Put Fram xtra guard oil filter on with Mobil 1 synthetic oil. Exp has 43000 or so on it. I thought the cam chain tensioner and guides were only probs with the sohc models?
Old 01-15-2004, 05:53 PM
dogman's Avatar
dogman
dogman is offline
had the same problem the dealer had a update for that part and they fixed it at no charge. I have a 2000 X. need to see the dealer there is a recall on the drivers seat a bolt has to be replace and the cable for the crusecontroll.
Old 01-16-2004, 10:04 AM
ExplorerSp0084
Is it a TSB or recall problem? If so do you know the number just so I can help the guys at ford find it a lil quicker. Thanks alot guys.
Old 01-16-2004, 10:14 AM
96explorereddieb's Avatar
96explorereddieb
96explorereddieb is offline
The OHV engines don't have the cam tensioner problems, only the SOHC engines have that problem. I've heard from people on the Explorer Forum that it was just a design flaw and will not cause any damage to your engine. They have to live with the noise but it's nothing major.
Old 01-16-2004, 12:00 PM
ExplorerSp0084
Well its going to the shop wed, Im hoping its nothing but Ive never noticed it before. I also just recently changed out the flowmaster exhaust so theres quite alot of stuff im just now hearing
Bugly
1983 - 2012 Ranger & B-Series
10-29-2016 05:09 AM
Kelly Crerar
2009 - 2014 F150
08-27-2016 06:22 PM
Budman1962
Modular V10 (6.8l)
21
12-25-2015 10:38 PM
DMC12
2004 - 2008 F150
08-09-2014 05:34 PM
Shadow351
2004 - 2008 F150
06-17-2013 05:20 PM
Quick Reply: rattle/loose chain sound whith startup.
