1972 Ford f250 problems
Old Jan 17, 2004 | 08:50 PM
willowbilly3's Avatar
willowbilly3
On my 68 the fuse contacts get rusty and ai hve to clean them about twice a year. Also it could be a bad light switch.
Old Jan 17, 2004 | 10:20 PM
orich's Avatar
orich
You lucked out young man, It sound like your on your way to building back up what someone let run down.
orich
Old Jan 17, 2004 | 11:15 PM
Derrick1972's Avatar
Derrick1972
Yeah I really consider my self lucky, Every thing except the engine is original still got the philco am radio. Its a camper special with the ranger package it came with all records from the second owner who was good freinds with the original owner. I even still have the original booklet for the truck and the window sticker. It only has a little surface rust and the front of the bed is dented toward the cab but all in all for $500 I think I found the best for my money. Like I siad this is my first Ford and I am loving every minute of it. thanks everyone for all the help
Old Jan 18, 2004 | 09:01 PM
Derrick1972
well my stalling problem came back, weel everyone i need to knw what to do to rid myself of this problem forever. it will not stall out if i push the gas down all the way but if i only push it down a little it will stall out and it feels like it is not running with all its power. when it did not stall it had way more power. I had this problem the last time it rained and when it ran good it was not raining, Now it has started raining again it runs like crap please help thanks
Old Jan 18, 2004 | 11:10 PM
orich's Avatar
orich
Sounds like bad plug wires
Old Jan 18, 2004 | 11:22 PM
Derrick1972
Ok I will give that a try tommorrow and see how it goes from there. while I am at the auto parts store is there anything else i might want to get for the truck that might need replaceing or maintenance.
Old Jan 19, 2004 | 02:59 AM
Opiewan's Avatar
Opiewan
cap and rotor if you havent done that yet, most of all tak your time and do one thing at a time. you will figure it out sooner or later. make sure all your vacume lines are good and your gas lines are good, clean up your engine so you can see everything , my engine now is so clean you can eat off it. (see my gallery for picture) so when something leaks i see it and excatly where it is coming from. cheapo brake cleaner does wonders on a dirty engine, i think oreilys brand is only 99 cents a can.
Old Jan 19, 2004 | 03:51 AM
willowbilly3
If you haven't checked the accelerator pump, then you should. I am not sure if your parts store carries it seperate but it is easy to change out. Just a thought but I don't think it would be affected by wet weather.
Old Jan 21, 2004 | 02:13 AM
Derrick1972
changed the plug wires and it ran fine for a day, now my trucks slams around like its only gettting surges of gas and it backfires like a shotgun blast so what do i do next????????????????
Old Jan 21, 2004 | 02:18 AM
samckernan's Avatar
samckernan
Just a thought, maybe your coil is intermittently opening.
Sam
Old Jan 21, 2004 | 07:02 AM
Opiewan's Avatar
Opiewan
are you sure you got it timed right ?
Old Jan 21, 2004 | 07:21 AM
willowbilly3
You prbably got a couple plug wires crossed, it is easy to do. You will need to find #1 and follow the firing order around the cap in the direction the rotor turns. The firing order is cast into one of the intake manifold runners.
Old Jan 21, 2004 | 08:38 AM
  #28
orich's Avatar
orich
Derrick1972,
Check & recheck, I hope someone did not put on a EGR valve on it. If so plug off the line going to it... Well if you go back to all the post that we guys did for you, and you will see that you missed doing 1 or 2 of the things will listed that you should do too keep that great old truck running good. So slow down and recheck things ...Good Luck
Old Jan 21, 2004 | 12:48 PM
  #29
willowbilly3
Originally posted by orich
Derrick1972,
Old Jan 21, 2004 | 12:50 PM
  #30
willowbilly3
OOPS, pushed the wrong button.
The problem with Ford egr valves is that they crud up and hang open. Unplugging the hose won't help this. You can try to clean it, replace it, or my favorite trick; use a chevy starter ship to just block it off.
