Sponsored by: Real Truck
gear ratio's
Old Jan 15, 2004 | 12:00 PM
johnny 99's Avatar
johnny 99
gear ratio's
When picking gear ratio's for your new truck, how should you decide what best suits you. I've always used the 3.73 limited slip because I did snow removal with my 2 350's, and the dealer said that would be the best. I'm in the process of buying a new one for more "personal use" and was wondering if I should change. Per say if I was going to do more highway driving?
Old Jan 15, 2004 | 12:47 PM
Autobahn F-250 Lariat's Avatar
Johnny 99,
I would go with the 3:73's if you are going to do alot of hwy driving however, if you plan on towing a lot go with the lower gears. What are looking for a PSD or gasser, getting lift kit in the future, upgrading to bigger tires these are a few of the factors that you may consider when choosing your gear ratio. I'm sure some of SD gurus will be in shortly to offer some more insight. Just my $.02.
Manny
Old Jan 15, 2004 | 01:33 PM
johnny 99's Avatar
johnny 99
It will be PSD, and I probably will go with larger tires in the future.
Old Jan 15, 2004 | 04:01 PM
RedCrewCab4x4's Avatar
RedCrewCab4x4
Johnny 99,
I'd definately go with 4.10 gears if you are going to put larger tires. The ratio will drop back to around 3.73 if you'd put 35s; perfect for highway and around town. Having 3.73 myself, putting 35s on would give about a 3.5 ratio, way to low if you tow, imo. One reason I still run stocks.
RedCrewCab4x4
Old Jan 15, 2004 | 07:26 PM
cwb's Avatar
cwb
Any tires over the stock 31's will make you yearn for those 4.10's. Definitely better to get them to start with.
