Exhaust Leak
Old Jan 15, 2004 | 11:24 AM
Wilsea's Avatar
Wilsea
Question Exhaust Leak
I have a 1988 XLT Bronco With a 351w. I developed an exhaust
Tick. Seeing that the exhaust was pretty old I had it replaced.
The muffler shop told Me the leak was up by the exhaust manifold. I came on this forum and checked out some of the causes. I replace the pipe on the front of the passenger manifold up to the EGR. I pretty sure the manifolds aren't cracked. Does anyone have a sugestion what it could be? Is there a pipe or sensor on the back of the manifold?
Old Jan 15, 2004 | 01:16 PM
slc10844's Avatar
slc10844
Sometime the manifold has to be taken off to see the crack. Not uncommon on the 302 & 351.
Old Jan 15, 2004 | 01:26 PM
sigma's Avatar
sigma
The exhaust manifold gasket is probably leaking.
Old Jan 15, 2004 | 07:55 PM
95 F150's Avatar
95 F150
From the factory there is no exhaust manifold gasket to blow out , well for sure on my truck there wasn't. If your exhaust manifold is bad then this is a very good excuse to buy some shorty headers
Old Jan 30, 2004 | 08:27 AM
bob arrington's Avatar
bob arrington
or put a gasket in, good luck,bob
Old Jan 30, 2004 | 09:11 PM
WhëëlMå1's Avatar
WhëëlMå1
You should get a piece of flexible tubing and use it as a stethoscope. That should help you determine exactly where it is coming from. It sure sounds like you have a cracked manifold.
Rich
Old Jan 30, 2004 | 11:27 PM
homerstud's Avatar
homerstud
I have also heard that most fords of that time dont have gaskets
Old Jan 31, 2004 | 11:22 AM
bob arrington
several didnt, thats why the usual fix is to give them one , metalic side facing out , of course,bob
Old Jan 31, 2004 | 02:09 PM
homerstud's Avatar
homerstud
great
Corpsman24
26
May 30, 2023 03:06 PM
stemo76
May 16, 2014 02:43 AM
Tomm
1983 - 2012 Ranger & B-Series
Jan 28, 2010 04:04 PM
FLYBOY07
Nov 21, 2009 02:25 PM
ftcav
Mar 2, 2007 11:42 PM
