i need a bigger altinator
Old Jan 14, 2004 | 10:41 PM
dnmyoda's Avatar
dnmyoda
i have an 86 f150 302 w/ an 80 amp alt. but I am planing on converting to 4x4 and want more power between my stereo lights and every thing else(i love my gadgets) my alt. does not seem to put out enough to handle one of the new fisher electric over hydrlic plows what can i do to fix this problem i was just forced into buying the 80 amp because i killed the 65 amp that was on it
Old Jan 15, 2004 | 05:19 AM
locknkey's Avatar
locknkey
A 130 amp does nicely....they are specially made for Ambulances and Police Units...(they have LOTS of lights,,so go figure) Cost is around 150.00 rebuilt with exchange, Some Autos require special mounting brackets and/or Voltage regulators. You will need to exchange another Alt to complete the cord charge or pay for the cord charge.
Old Jan 15, 2004 | 06:45 AM
bremen242's Avatar
bremen242
Check this site out:
http://www.4alterstart.com/highoutputalternators/
They have some serious (200amp) jobs. You have to do a little bit of mods to get it to fit, but well worth it.
Old Jan 16, 2004 | 12:44 AM
DanMartin's Avatar
DanMartin
Cool! 200amp, 90amps at idle!
So, which one from their list for our trucks? The one listed for the Mustang?
Old Jan 16, 2004 | 06:42 AM
bremen242's Avatar
bremen242
Yeah, the 94-95 mustang alternator. You'll have to grind the bracket down a bit and swap pulleys and ditch the external regular. Do a search for "3G alternator swap" or check this page out:
http://www.bcbroncos.com/3ginstall.pdf
Old Jan 16, 2004 | 06:19 PM
otto's Avatar
otto
you could just add another 100 amp alt possibly, another thought is using your P/S pump to run the plow or adding a belt driven hydraulic pump with joystick control and solenoid valves running your up/down, left/right, straight plow/vee-mode... now your talking
Also 2 1000 CCA batteries is mandatory for electric motor plow rigs
Old Jan 17, 2004 | 12:12 AM
archangel's Avatar
archangel
Hey, that (http://www.bcbroncos.com/3ginstall.pdf) was cool!
Do you know if there is one for the late 80's corvette (the ugly one) alternator?
I have a 130 amp internal regulator unit that has one pos stud, and three wires, one red and two are brown and all three are next to each other and I looked at the wiring diagrams for it and am unable to tell which brown one goes to what!
Old Jan 17, 2004 | 06:48 AM
bremen242's Avatar
bremen242
Not sure on GM. I think they are internally regulated. I think a haynes/clitons should show the wiring..
Old Jan 17, 2004 | 10:38 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Instead of huge CCA batteries that are not kept full all the time, try some deep cycle marine batteries instead. They will last much longer with all the charge / discharge cycles while plowing.
You always have some lots that you are running to slow to keep the batteries up and running the plow hoist almost nonstop. No alternator will keep up with the plow / lights drain while plowing them. The deep cycle will not cook from this like the mega CCA batteries will.
Old Jan 17, 2004 | 01:35 PM
archangel's Avatar
archangel
Those 200 amp alternators should do the trick!
How about running two 200 amp alternators?
One primarily hooked up to each 1000 cca battery?
You can also change the drive belt ratio so they pull faster rpm's at lower engine speeds!
Old Jan 17, 2004 | 04:38 PM
dnmyoda's Avatar
dnmyoda
my truck is internely regulated what would i have to do wireing wise to make it fit or would it just plug right in my motor and computer is out of an 88 mustang 5.0 but has the truck brakets for the accesories
Old Jan 17, 2004 | 06:04 PM
DanMartin's Avatar
DanMartin
dnmyoda,
I believe the link that bremen242 posted above from bcbroncos.com explains it pretty well. Please take a look at their diagram...it appears to be a pretty simple swap.
