cleaning my m5sd
Old Jan 14, 2004 | 08:10 PM
jakemarty90's Avatar
jakemarty90
cleaning my m5sd
Have 95 4x4 I6 with m5sd. I'm replacing clutch slave and while trans down removed top cover and even though the gears all look good they are covered with a black film like you would find in the bottom of an auto trans. When I pulled the drain plug magnet it was covered with more of the same material. Tranny runs and shifts fine but was wondering if this is normal. Also, I want to clean it out...what should I use?
