Just Bought 1989 F250 2X4
all 89-90 trucks with x-cab were "heavy duty", or base 1 ton vehicles.
I had mine for a while now. Problems:
Idle Air control motor went bad, it wouldn't idle. Very easy fix. Aftermarket unit works just fine.
Window motor gears. Kind of bitchy to replace. Took me 3 hours in all honesty. Dropping tools inside the door. Both failed at about the same time.
Fuel pump sending unit. The pump still works well, but registers no gas. It is integrated into the pump. You have to drop the tank and replace it.
No problems with drivetrain, either 7.5L or C6 tranny.
newtoford1989
05-15-2011 09:36 PM
hotrodd
06-23-2005 10:55 PM
