EGR problem Please help
Old Jan 14, 2004 | 07:08 PM
Billy Ray's Avatar
Billy Ray
Can anyone tell me where the EVP sensor for the EGR valve is located on a EFI 96 F-150 with a 302? I have been having a CE light on solid for days. I had code pulled at Auto Zone and it came up EGR problem. I can't remember the specifics. I took EGR off. No buildup inside. I opened valve by pushing up with a screwdriver then held my finger over the vaccum inlet and removed the screwdriver, the diaphram held the valve open until I took my finger off vaccum inlet. EGR should be ok. I pulled vaccum line off egr and I might have had a little vaccum when I raced the engine, hard to tell. I traced the vaccum line as far as I could see and it went into , what I suppose is a sensor, on the drivers side of intake.( easy to get to) It has two wires out the top and one more vaccum line( with vaccum at idle and rev) going in below the line from the EGR . I unpluged the EGR line from sensor leaving the full vaccum line on and raced the engine and no vaccum pulled from the unpluged EGR tube on the sensor. Does this sound like the EVP sensor and the problem? Please help.
Old Jan 14, 2004 | 08:32 PM
Egor's Avatar
Egor
I believe that sensor you are messing with is the EVR. Exhaust valve regulator (or something like that). Vacuum goes through that before it gets to the EGR valve. The EVP sensor is on top of the EGR valve itself, unless they changed it from the 90 style. Anyway that EVR is right by the coil on my 90 5.8
Old Jan 14, 2004 | 08:38 PM
95 F150's Avatar
95 F150
Do you know the code# , my truck threw an egr related check engine light for a month and half code #332 (insufficient EGR flow) and it turned out to be a vacuum line going to the coffee can.
