Found a leak in my fuel line. It was in the line from the lift pump to the fuel filter. I cut out the cracked part and put in a piece of rubber line for a temporary repair. Caused, it appeared, by someone elses repair on the adjacent line - they had done the same but left the screw head rubbing against the line I had to repair. After x years and on a 5 degree morning it gave up :-(
Does anyone know where I can get both these lines and what exactly to ask for?
if you want exact replacement , ford or napa, that lift pump is not high pressure so if you needed to ,the rubber fuel line would work fine. good luck ,bob
