Fuel Line Question
Old Mar 16, 2005 | 09:57 AM
79bob's Avatar
79bob
Question Fuel Line Question
This past weekend I removed the old rusted bed from my 79 4x4 truck.
I am replacing it with a wood flat bed. Before installing the new bed I want to replace the old fuel line from the tank to the fuel pump. The old line has been repaired many times with rubber and copper line with hose clamps. My question is, what should I use to replace this fuel line. Can I use rubber fuel line or must it be steel. Any help would be great.
Old Mar 16, 2005 | 10:01 AM
crecity678's Avatar
crecity678
rubber will work fine, keep it tucked away, if your worried use an anti abrasion sleeve over it
Old Mar 16, 2005 | 11:07 AM
73Custom's Avatar
73Custom
If I were going to the trouble, I'd use metal. Rubber will rub through, dry and crack, and not as safe as metal. But that's me...
Marty
Old Mar 16, 2005 | 01:08 PM
77460f150's Avatar
77460f150
I agree with 73custom I used 3/8" steel brake line with short lengths of 3/8" rubber line to make connections, now it should be good for 30 more years!! -Ed
Old Mar 16, 2005 | 02:21 PM
460f250's Avatar
460f250
I used rubber, just made sure it was secure and wouldn't wear on something.
I'd say comparing the rubber we have now and the metal in the brake lines that each will last just about as long, barring damage.
Old Mar 16, 2005 | 02:45 PM
jstandle's Avatar
jstandle
FYI if you ever plan to race it anywhere on a sanctioned drag strip (maybe, maybe not) I believe the maximum of rubber line that can be used between engine and tank is 12 inches.
Old Mar 16, 2005 | 08:57 PM
Mil1ion's Avatar
Mil1ion
I'd go metal just like the factory did.
Old Mar 16, 2005 | 10:13 PM
IronWorker3's Avatar
IronWorker3
If you're planning on keeping the truck i'd go metal all the way. You can go with rubber but you're taking a chance. Go with metal, no worries.
Old Mar 17, 2005 | 12:19 PM
beartracks's Avatar
beartracks
Metal is the only way to go and stainless is the best choice. Summit Racing has kits I believe.
I'd use braided for any parts that need movement.
Old Mar 17, 2005 | 07:08 PM
GeneStoner's Avatar
GeneStoner
If you want to lighten your truck (toungueNcheek), theres always aluminum fuel line from Moroso...
Old Mar 18, 2005 | 08:09 AM
cigarxtc's Avatar
cigarxtc
Exactly what I did. I went down to my local speed shop and got a roll of aluminum fuel line for under $30. It's more than enough to replumb all my fuel lines and then some. Also, with the aluminum lines you won't have to worry about it rusting and rotting out in a few years.
Or if you like crawling under yer truck every year you'll have to be replacing the rubber fuel lines often. The weather and heat just eats that stuff up. I used as little rubber on my replacement fuel lines as possible.
Old Mar 18, 2005 | 09:45 AM
beartracks's Avatar
beartracks
A caution about aluminum fuel lines. Make extra sure it is secured with clamps that wont rot out. If the line can vibrate it will rub a hole in itself.
Old Mar 20, 2005 | 10:32 AM
sixgunkelly's Avatar
sixgunkelly
where else can you get "Aluminum Fuel Line" in a roll like that.I'd like to replace all in a 78F250 .Also wanted to replace all brake lines.... any ideas, do they have brake line kits for that year or is there other ways to do it?? Preciate the comeback,Bruce
Old Mar 20, 2005 | 03:24 PM
GubNi's Avatar
GubNi
I used 3/8 brake line. It was coated on the outside to prevent rust. I used couplers to join it together. I have very little rubber on my fuel lines.
Old Mar 20, 2005 | 06:03 PM
cigarxtc's Avatar
cigarxtc
Ditto, to what beartracks said. If you're careful, you can remove the factory steel lines and use them as the model to shape and bend the aluminum lines. Afterwards, My aluminum fuel line fit in all the factory Ford plastic clamps that are permanently installed on the frame. Heya, Bruce, you might wanna check out the FTE Parts shop or any of the online racing supply stores. It might be faster and easier to just call your local speed shops in the yellow pages first. I got a whole roll of Edelbrock fuel line at a great price at my local speed shop here in Tulsa.
