Sponsored by: Real Truck
OverDrive Button
Old Aug 8, 2002 | 06:42 PM
rsjohnsn's Avatar
rsjohnsn
OverDrive Button
My overdrive button is messing up, it only works occasionally. Sometimes when it doesn't work I can move it around and it works fine for a while then back to nothing. Can they be replaced or just cleaned? If so how do you get it apart? Has anyone else had this problem?
Thanks
Old Aug 8, 2002 | 08:45 PM
Monsta's Avatar
Monsta
Sit. Stay.
OverDrive Button
I've heard of the wire inside breaking. Maybe yours is about to go? Pull the switch and check it out.
Old Aug 8, 2002 | 09:07 PM
rsjohnsn's Avatar
rsjohnsn
OverDrive Button
Thanks Monsta but how do you get it out?
Old Aug 9, 2002 | 10:51 PM
charlesvalentine's Avatar
charlesvalentine
OverDrive Button
I had the problem and fixed it by:
1.) on the window side of the cap around the button, insert a screw driver and pop the cap off (dont worry if ya break it cuz it a cheap part like $1.00)
2.) fingernail the button out
3.) remove plastic around steering column (three screws on bottom)
(to remove the lock cyl put the key in and turn it to the run position then press the nipple on the bottom with a scratch awl and pull the cyl out)
4.) unsnap/plug the harness connector from from the wire that comes out of the gear lever ( it is right over were the column tilts)
5.) Use a continuity cker to test that you get good electrical connection on each of the three wires. Be sure and jiggle the wire while cking as the connection may be intermittent.
6.) if you get good tone on all three wires it may be the button. but in my case the wires were giving intermittent contact.
The button is about $10
If the wire is the culprit you have 2 options. do what I did. Yank the wire out and make your own new harness. I did this with telephone wire (the stranded type) or you can purchase a replacement gear lever. It sucks but Ford does not sell just the wire or harness. You have to pay around $50 for the whole lever.
To install the lever there is a clip that you remove. its pretty obvious once you get the thing apart. It took me about 45minutes to do the remake the harness fix and cost about a $1.
Good luck@! email me if ya have more Q's and I'll be happy to answer them.
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
Old Aug 10, 2002 | 08:02 AM
rsjohnsn's Avatar
rsjohnsn
OverDrive Button
Thanks for the help Charles, I'll give it a try today.
Old Aug 10, 2002 | 09:15 AM
Monsta's Avatar
Monsta
Sit. Stay.
OverDrive Button
Excellent reply charlesvalentine!!
Sorry for the delay, Scott but it looks as if he squared you away! Let us all know how it turns out, okay?
Old Aug 10, 2002 | 11:39 AM
tigerman's Avatar
tigerman
Post OverDrive Button
