1995 explorer knocking when excelerating
Old Jan 14, 2004 | 12:57 AM
sofieca's Avatar
sofieca
My 1995 explorer knocks and rattles when under exceleration and load has anyone had a similar problem When it warms up it either goes away or lessens in severity.
Old Jan 14, 2004 | 01:34 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE sofieca The 4.0 OHV engine is prone to detonation due to carbon buildup. I posted the TSB contents almost a year ago concerning this issue in the Ranger forum, do a search and it should show up. This is fairly common on this engine; I've implemented it and it does work. Generally this happens with engine warm and under moderate loads.
On edit:
You asked if anyone else haa had this problem, and the answer is yes, it's pretty common. Also, a dirty MAF sensor is frequently associated with this problem, it's easy to clean. Do a search and you will find the process for cleaning it. IMHO, try cleaning the MAF
sensor first.
Old Jan 14, 2004 | 06:03 AM
mustangsvt's Avatar
mustangsvt
or do it the italian way and step on the gas to flush er out
Old Jan 14, 2004 | 11:17 AM
mrshorty's Avatar
mrshorty
Any kind of small vacuum or air intake leak downstream from the MAF can cause it to run lean and ping. Check your vacuum hoses. Also check the lower intake manifold bolts. They come loose creating a small vacuum leak through the gasket. Usually tightening the bolts is enough to correct it.
Old Jan 14, 2004 | 11:39 AM
White97's Avatar
White97
Not limited to the v6, I have a v8 and cannot get rid of this noise. Same thing under load and when cold.
brent penfold
Exhaust Systems
Aug 12, 2015 04:46 PM
montecarlo
2011 - 2019 Explorer
May 17, 2015 02:11 PM
catzr440
May 1, 2015 05:18 PM
smokingjoe88
Jan 12, 2015 07:44 AM
Liomee
1983 - 2012 Ranger & B-Series
Mar 28, 2014 02:30 AM
