Bronco II Ford Bronco II
Front Diff
Old Jan 13, 2004 | 11:20 PM
88' Bronco II's Avatar
88' Bronco II
Question Front Diff
Is the front differential a 7.5 just like the rear? and what does it take to change theme to 4.11
Old Jan 14, 2004 | 10:23 AM
mrshorty's Avatar
mrshorty
No. The front differential is a Dana 28 Twin traction beam. Assuming the 4.1 ring and pinions are available, It's like any other gear change. Replace the old ring and pinion with a new ring and pinion (and all of the little details that go with it). I'm not sure about carrier breaks, so you may also need a new carrier.
Good luck.
Old Jan 20, 2004 | 01:02 AM
88' Bronco II
thanks for the help
