transmission issues.
Old Jan 13, 2004 | 10:51 PM
modru2004's Avatar
modru2004
trucks in sig with c6. anyway when i shift out of park sometimes it doesn't shift at all. ill have it on reverse but its still in park. seems to be happening more frequently too. any ideas about whats going on, is it something i should be worried about? shifting back to park then back to revers drive etc fixes it but it seems to be occuring more often. also under hard acceleration is the orange marker supposed to slip almost completely off drive, to the point where its almost on neutral? it has yet to slip out of gear but then i keep correcting it.
Old Jan 16, 2004 | 04:28 PM
modru2004's Avatar
modru2004
bump any help?
Old Jan 16, 2004 | 07:29 PM
wickedboy32's Avatar
wickedboy32
i had an old ford that had same problem it turned out to be a broken motor mount under acceleration the engine would lift off broken motor mount and twist tranny linkage out of aliment start with checking motor mounts
Old Jan 17, 2004 | 12:15 AM
modru2004's Avatar
modru2004
the engine itself does shake do to ageing mounts. ill look into it.
Old Jan 17, 2004 | 01:33 AM
Boss_358's Avatar
Boss_358
It does sound like your shift linkage is being disrupted somehow.
