Holley Electric Choke
Old Jan 13, 2004 | 03:46 PM
Mustang6t7's Avatar
Mustang6t7
I just received my new holley 600 cfm. carb, it has an electric choke can you tell me the correct way to wire it? It has (2) two terminals coming off the black choke housing.It is for a 1967 Mustang 289
Thanks
Jim
Old Jan 13, 2004 | 04:07 PM
lee's Avatar
lee
Jim
Welcome to the site.
One wire is for ground and the other goes to the "S" terminal of back of the alternator.
Hope this helps.
Old Jan 13, 2004 | 04:10 PM
Mustang6t7's Avatar
Mustang6t7
Thanks For The Information It will help,This Is On A 1967 Mustang with 289
Old Feb 25, 2004 | 04:52 PM
debestuss's Avatar
debestuss
Is the "S" terminal the hot post on the alternator? I have one, too but I have it hooked up to the Accessory wire from the ignition.
Old Feb 25, 2004 | 05:07 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I have a 750 holley on my 390...blk to ground and red to a 12 volt source....when the ignition is on!! Good luck!! Russ!!
Old Feb 25, 2004 | 05:08 PM
debestuss's Avatar
debestuss
Cool
Old Feb 26, 2004 | 02:07 AM
Superdave's Avatar
Superdave
debestuss
The "S" terminal is one of the smaller terminals on the back of the alternator.
Old Mar 29, 2004 | 02:23 PM
FERacing66's Avatar
FERacing66
can you wire it to the voltage reguatlor?
Old Mar 29, 2004 | 10:51 PM
LxMan1's Avatar
LxMan1
Yes, wire it into the stator wire. This way it only has voltage when the engine is running.
