Sponsored by: Real Truck
shocks, leveling kit
Old Aug 6, 2002 | 03:10 PM
jalawso's Avatar
jalawso
I have a 2001 f-250 supercab v10 4x4 automatic. I want to get a front end leveling kit that raises the front end 2 ½”. I am not sure what brand to go with as far as the leveling kit goes. For the shocks I am deciding between rancho’s new rs9000x with 9 adjustable settings, procomp’s mx6 with 6 adjustable settings, and bilstein shocks which are suppost to self adjust. Which shocks should I choose and what brand leaf spring should I get to raise the front end 2 ½”? Thanks for all your help.
Old Aug 6, 2002 | 03:34 PM
Overkill's Avatar
Overkill
FTE *******
Jalawso, if you want the best possible ride quality and construction go with a 3" Edge kit by Donahoe Racing. The kit utilizes bombproof spring hangers and shackles, and includes custom valved Bilstein 5100 shocks. This is the only kit on the market that will provide you with better than stock ride quality. Hope this helps.
__________________________
Overkill, 2000 X 4x4 Limited,V10, Black Monochrome, The Edge 12.5" Lift, The Edge Adjustable Track Bar, The Edge Monster Truck Traction Bars, The Edge Dual Shock Hoops, Bilstein 7100 Shocks (Custom Valved), ORU 7100 Dress-up Kits, ORU CrossOver Steering & Hydraulic Assist, High Angle Drivelines, 18/39-16.5 M/T Baja Belteds, 16.5x14 Weld Mountain Crushers, Crystal Head Lights & Corners, Trenz Billet Grill, ORI PreRunner Bar, Hella 3000s, Billet Fuel Door, Kodiak Power Steps (4), Con-Fer Dif Covers, Go Rhino Trusses, 5.13 Gears, Superchip, Borla Exhaust, Volant Filter, BBK TB Spacer, Custom Dark Graphite Carpet & Headliner, Custom Black Leather Seats, Custom Molded Carbon Fiber Interior Trim, Trenz Billet Door Sills, Weathertech Mats & Liner, Eclipse 7301 Multi-Media, McIntosh MC4000M, Focal Utopia 165W3 (2), Illusion Audio nd12 (4), Stinger Caps & Wires, Q-Logic Kicks, Custom False Spare Tire/Sub Enclosure
Old Aug 6, 2002 | 03:58 PM
Waxy's Avatar
Waxy
BDS Suspension makes a 2.5" levelling kit that uses the stock springs to maintain the stock ride. It basically consists of new shackles, spring hangers, etc... You can use any type of shocks you want with it, they reccommend either the Rancho 9000's or the Bilsteins.
It's not cheap though, at around $700 CAN it's a little outta my price range. If it was $350 I'd have one on my truck already.
Here's their website. www.bds-suspension.com
If you get a quote, let me know.
Waxy
Old Aug 7, 2002 | 09:54 AM
jalawso's Avatar
jalawso
Which shock do you guys think is the best for what i have and want? Pick from the three I talked about above.
thanks
Old Aug 7, 2002 | 10:48 AM
Overkill's Avatar
Overkill
FTE *******
Jalawso, the Bilstein 5100s included with the Edge kits are the only shocks available which are custom valved for SDs. If you buy a RS9000, MX6, etc., it doesn't matter if you order them for a Toyota or an SD. You get the same shock, albeit in different lengths. Furthermore, the new 5100s come in a bright brushed silver coating that looks SWEET.
Old Aug 9, 2002 | 10:41 PM
HeavyAssault's Avatar
HeavyAssault
If you go to Fly-N-Hi Off-Road they have a shackle kit for $279. I like mine and the truck looks great
I picked up the Bilstien shocks and would not change for anything.
What is the cost of the EDGE kits anyway???
Old Aug 10, 2002 | 12:17 PM
Overkill's Avatar
Overkill
FTE *******
HeavyAssault, the Edge hanger kits run $465 which might sound a bit high, but they are apples and oranges to the Fly-N-Hi kits. Even the Fabtech hangers which are $10 more are toys by comparison. The Edge hangers are bomb proof and are probably stronger than the frame they are attached to. Also, they utilize a longer shackle instead of dropping the shackle mount as with the FNH kit. This also contributes to the improved ride quality.
Old Aug 12, 2002 | 04:38 PM
jalawso's Avatar
jalawso
hey overkill, whe do the edge kit not include new leaf springs? I would think you would need to add a leaf or something.
Old Aug 12, 2002 | 05:47 PM
abendx's Avatar
abendx
Old Aug 12, 2002 | 06:24 PM
jalawso's Avatar
jalawso
why does not whe do
Old Aug 13, 2002 | 08:48 AM
Overkill's Avatar
Overkill
FTE *******
Jalawso,
Here is your answer straight from Kreg Donahoe, owner of Edge:
"Stock springs have the least amount of spring rate, Agreed??? Add spring hangers that lift the truck to clear 35" tall tires... Add a custom Valved shock specific for that trucks kinetic energy to that low spring rate... WHAT do you GET???? A lift system that will clear 35" tall tire, that will articulate fully, and that gains wheel travel, as well as Rides WAY BETTER then stock simply because you added a better shock. That's How. No other lift company makes a kit that will clear 35 that rides as nice as ours."
He was of course speaking of the 4.5" Edge kit but the same is true for the 3".
Old Aug 13, 2002 | 09:20 AM
jalawso's Avatar
jalawso
thanks for all your help.
alex--taylor
Mar 19, 2015 06:37 PM
King-bRanch
Apr 3, 2014 06:01 PM
icentropy
Sep 7, 2013 06:55 AM
Bitt19
Aug 28, 2005 04:00 PM
5.4AZ4X4
Nov 26, 2004 04:54 PM
