Expy LLS to spring conversion
Old Oct 17, 2004 | 11:30 AM
  #46
Daddy4zack's Avatar
Daddy4zack
Has Anyone figured out how to keep the "Check Susp" light from coming on?
Thanks
Old Nov 16, 2004 | 09:58 AM
  #47
typhoon1911's Avatar
typhoon1911
Lama,
Thanks for the great info.
For the Rear OEM spring conversion install...
1) Will it work with the drop coils as well?
2) Is there anything special holding the coils on?
I am sure I am not the first one that is trying to do this (rear air convert to drop rear coils), but there is no one who has posted their findings.
Thanks Again,
Alan
Old Nov 16, 2004 | 10:21 AM
  #48
Lama's Avatar
Lama
You can install any rear spring, as long as it is wound correctly for the Expy. Nothing is holding it in except its correct shape that fits into the upper and lower pockets. The vehicle weight keeps it in, and the sway bar should not let the springs pop out if you jack up the vehicle on a hoist.
A hui hou.
Lama
Old Nov 16, 2004 | 08:29 PM
  #49
typhoon1911
Thanks Lama for you informative postings...
Now I just need to order the Eibach coils all around ($310 including shipping to Hawaii) and thoses coil insulators from Ford ($13 each special order)...
By the way you local from Hawaii?
Alan
Old Nov 29, 2004 | 03:41 PM
  #50
thmpsn5's Avatar
thmpsn5
hello all, new to the site. i have a 99 EB expy with the 4 corner lls. P.O.S!!! i want to do the coil conversion. sounds like strutmasters is the way to go. cant find a link or phone#. probably right in front of my nose.thanks.
Old Mar 5, 2005 | 03:40 AM
  #51
Ramphog's Avatar
Ramphog
About howm uch did this run you?????
Originally Posted by Lama
If you want to get rid of the LLS system on your Expy:
Front: (4wd LLS) Remove original air shocks and install normal shocks:
Monroe: 32080 (Monroe-Matic) or 34911 (Gas Adjust)
KYB 344071 or KG5414
Napa NS 94010, or RR20704 or NS76911
Basically, a 1966 Ford Bronco (to S/N 830001) shock, rear application.
Rear: Pry out airbags (just held in with metal clips, (bleed all air out first),
a) Install correct rear FORD OEM Expy/Navigator coil spring. Realize you need to be aware of your vehicles configuration, i.e. 2wd, 4wd, Sport, Rear Air, Tow package, etc. to get correct spring height and rate. Get the rubber coil spring isolators also.
b) Strutmasters, Inc. has a rear coil spring replacement "kit" (a pair of springs) that I used, but have had trouble with, but they are working on resolving this issue.
Rear shocks: You can leave the originals in there if not leaking, or replace with any correct P/N shock for your year Expy.
When done, leave air susp. switch in "ON" position, but disconnect the large electrical connector powering the air pump, under the washer fluid reservior, or remove pump completely. This will keep the "CHK SUSP" light from staying on.
I got sick and tired of dealing with LLS problems, and the noise the pump makes.
Hope this can help others kill this POS idea by Ford.
Old Jun 24, 2005 | 02:06 PM
  #52
hceptj's Avatar
hceptj
Thanks
I just finished the conversion using the strutmasters stuff...front and rear...last weekend.
Strutmasters sent info on how to get rid of the check susp light:
1. The box for the controls to the LLS (and a couple other things) is located just under top of the dash...just behind the radio.
2. If you pull the radio bezel off, then the screws holding the dash (a dozen or so) you can get to the box (its black, about 1-1.5" thick, 6" wide, and 8" or so long).
3. It has two plugs, one black and one gray. According to strutmasters (and it worked for me) you have to cut the dark green w/light green stripe wire.
4. My wire is in the gray plug and its the 2nd from the left on the bottom row.
I left the compressor plugged in and the LLS switch in the on position...no check susp light and the compressor stays off.
Hope that helps.
Old Jun 24, 2005 | 10:19 PM
  #53
Ramphog's Avatar
Ramphog
So the big question....... How does it ride!!!!!!
Old Jun 25, 2005 | 07:51 PM
  #54
EagleDakota's Avatar
EagleDakota
Hello everyone. I too have fought the battle of the LLS and have replaced compressor after compressor. Most of the re-mans are done in China and they fail regularly. Finally, I found Eddy Spinks at American Air Suspension. He rebuilds and Imprves the actual Ford unit and I have been very happy so far. He also sells a unit called a spider valve which will permit you to use a shop or gas station compressor to "re-inflate" the system manually so you can still drive the truck. He also sells conversion kits - that should make a point. It is much easier just to replace the compressor a few times than to change everything (IMHO). If someting else goes, that is another matter.
This is just another opinion. Here are American Air Suspensions" coordinates:
Eddie Spinks
Owner of American Air Suspension
Air Suspension Specialist
Ford/Lincoln Air Suspension Parts & Conversion Kits
311 Dry Fork Road
Del Rio,TN.
37727
Order Toll-Free# 1-866-487-4321
Office# 423-487-4321
Fax# 423-487-4318
www.americanairsuspension.com
Old Jun 30, 2005 | 12:26 PM
  #55
hceptj's Avatar
hceptj
Feels like a new truck to me...but it should with 4 new shocks and new springs right?
Very happy with it...no more worries about a failure somewhere in the system (had a bad front shock once and the small fitting over near the master cylinder go bad) and having to drive home with the rearend practically on the ground...
Old Jul 3, 2005 | 04:16 PM
  #56
Stealth111's Avatar
Stealth111
I hate to pop in late on this, but I own a 2000 Navigator, and I was wondering if can do the LLS to standard suspension mod on this as well.. It seems like it would be the same getup...but i did notice a few things in my search for parts.. for example the rear shocks... for an expy like my 2001 i can buy shocks for around the $30 area, and they have tons of different ones to choose from, but when i search for rear shocks for my 2000 Navi, I only see one choice at the parts store and they are bilstrein and they are $60 each... So I am wondering if the same stuff for the expy conversion would apply for my Navi... Do I still buy a set of shocks for the front for a 1966 ford bronco?? the parts store has front shocks listed for my navi as bilstein BE5-2574 or BE5-2575.. which seems odd that they even have them listed at all?? Do I buy their rear shocks for LLS or for standard suspension after the conversion?? Any help on this would be greatly appreciated!!
Old Jul 5, 2005 | 11:43 AM
  #57
Orlie's Avatar
Orlie
http://www.yellow94.stangnet.com/photo2.html
hope this works, photos and instructions on cutting the correct wire for deleting the check suspension light.
later
Orlie
Old Jul 8, 2005 | 01:43 PM
  #58
hceptj's Avatar
hceptj
later
Orlie
nice pics...lol, it says black on your sheet also...guess we should email them that they need to correct that...
stealth111...just cross whatever bilstein number they give you and see what it jives with for monroe's, kyb, etc.
Without knowing for sure if you have 4 corner LLS and if your 4x2 or 4x4, its hard to tell you about front shocks.
Here's a couple good links though...plus you should be able to cross that bilstein shock...
http://www.shockwarehouse.com/cgi-bi...ruck_make.html
http://www.monroe.com/catalog_lookup...e=ocl_ecatalog
http://www.pickproparts.com
Old Jul 14, 2005 | 09:35 PM
  #59
rconnjr's Avatar
rconnjr
I have questions. I want to install Monroe reflex shocks in my 97 expy when I do the conversion Front # 911133, rear# 911145. Will these work? It seems the part #s posted in this thread are mostly for Broncos, why is that? Also when I look up shocks, should I get the numbers for or without LLS? Do they mount different in the rear?
thanks.
Old Jul 15, 2005 | 09:28 AM
  #60
Lama's Avatar
Lama
You MUST use 1966 Bronco front shocks. The shock length mounting for a non-LLS Expy WILL NOT work.
The rear you can use a non-LLS or LLS Expy shock.
Thanks to al who figured out cutting the dk. green / lt. green wire. It works, it killed my check suspension light pronto.
While you are in the dash cutting the wire, if you have the notorious disappearing odometer display, it's a great time to do that repair also, as shown in the post elswhere on this forum.
