Sponsored by: Auxito
1999 150 wheel lug pattern please read
Old Jan 13, 2004 | 12:50 PM
tommytorino's Avatar
tommytorino
Guys
I would like to "snazz" up my 1999 F 150 with a set of Rims and Tires off a late model Fx4. My truck has the factory style rims and are 17". What years can I use? I am to understand that ford changes the rim style in 04. But can I use a 03 and down?
Thanks much!
Tommy in NY
Old Jan 13, 2004 | 02:38 PM
Alton Ray's Avatar
Alton Ray
Tommy,
I am pretty sure that the 03 and down parterns should fit your truck.
AR
Old Jan 13, 2004 | 03:12 PM
will-work -for-mud's Avatar
will-work -for-mud
I agree with alton. 2003 down to '97 models. They have the 5 on 135mm lug pattern.
-Landon
Old Jan 13, 2004 | 03:20 PM
MrBSS's Avatar
MrBSS
The newer trucks have 14mm studs. I believe the older ones had 12mm studs. I don't know if its considered safe to use the newer wheels on the earlier studs, but I would think they would have designed them so they wouldn't fit to prevent the problem if there was one. Still, if you have the 12mm studs, I would be careful.
Old Jan 13, 2004 | 03:32 PM
Alton Ray's Avatar
Alton Ray
If you are worried about the lug sizes I believe that you can change them out. Correct me if I'm wrong on this guys.
AR
Old Jan 13, 2004 | 11:45 PM
Racerguy's Avatar
Racerguy
I'm not sure if the wheel studs are interchangeable but you can use wheels for 14mm studs on a truck with 12mm studs as they wheels center themselves on the hub and not by using a taper on the nuts like on an older truck.
Shernius
WTB - Parts & other
Dec 27, 2014 10:48 PM
sutty
Jul 20, 2014 07:36 AM
Tim 79 F150
May 10, 2013 05:35 PM
schmidty_dog
1997 - 2003 F150
Jun 20, 2007 08:24 AM
