Help!
Old Jan 13, 2004 | 09:16 AM
BIGDOG38's Avatar
BIGDOG38
Help!
OK - have a post about 12 down, finally got the bucking to stop of all thing one of the new wires I installed was bad, now I have another prob. a high idle it wants to idle at about 1500rpm
replaced the IAC valve not helping, its a standard trans. when you pull up to a stop it wants to run away I have to release the clutch a little to get it to idle back down to 1500
anyone know what could cause this?
Thanks
Old Jan 13, 2004 | 09:18 AM
BIGDOG38's Avatar
BIGDOG38
forgot to say, if you turn the a/c on the engine speed doesn't change
Old Jan 13, 2004 | 06:43 PM
bigbadjs's Avatar
bigbadjs
Did you forget to connect one of the vacuum hoses? Sounds like a vacuum leak.
