2002 explorer
Old Jan 12, 2004 | 04:53 PM
red2001crewcab's Avatar
red2001crewcab
2002 explorer
I have a 02 eddie bauer explorer and was wondering if any one has any trouble with rear hatch. My wife found her hatch cracked under the rear glass. This peice is fiberglass and the ford dealer is going to fix this but I was wondering if this was common problem.The ford dealer said it cracked due to cold weather, it was 20 degrees. This is Georgia, if I was up north this would happen every day.
Old Jan 12, 2004 | 06:19 PM
02Explorer4x4's Avatar
02Explorer4x4
Our '02 is in the shop for the same thing right now. The plastic panel under the back glass had cracked in two places. The back glass had to be shut very hard to latch and I think that is what caused ours to crack. The latch was also replaced because of the hard shutting.
The dealer put a new piece on under warranty and was told that they had done this on other Explorers.
Old Jan 13, 2004 | 03:29 PM
red2001crewcab
I hope if this is a problem with material that ford will make improvements with replacement parts.
Old Jan 15, 2004 | 04:06 PM
Hellbender's Avatar
Hellbender
This is a very common accurance from what I've heard. Hasn't done it to mine yet but a freind's at worked cracked and had the scoop on this issue. He waited sometime for they were backlogged.
Old Jan 20, 2004 | 03:53 PM
red2001crewcab
The Ford dealer told my wife today that they did not know when the part would come in.
Old Jan 21, 2004 | 07:12 PM
Suyoung93's Avatar
Suyoung93
My one has also experienced that terrible thing. Today it was replaced. And I have a little problem when I close rear hatch.. It's not closed well, I have to close hard...Do you guys think that I should go to dealer?
