Aerostar Ford Aerostar
Aerostar T-case question Help Quick!!!!
Old Jan 12, 2004 | 04:32 PM
fordiesel69's Avatar
fordiesel69
Question Aerostar T-case question Help Quick!!!!
I broke my drivers side cv shaft today and was curios if I would ruin anything in terms of transfer case of differential wise. I really don't care about the damage to the CV or front end. My friend told me that the aerostars use a limited slip clutch assembly in the tcase to syncronize the front and rear axles. If this is true, are the clutches wrecked?
Old Jan 12, 2004 | 04:40 PM
aerocolorado's Avatar
aerocolorado
No, there is likely no damage unless you continued to drive it for an extended period of time.
Old Jan 12, 2004 | 05:12 PM
fordiesel69
Cool, by the way, how hard are they to replace?
They run $74 per side and $90 to install, I would rather do them myself if possible.
Old Jan 12, 2004 | 05:25 PM
aerocolorado
If you are you referring to the axle half shafts, they are fairly easy to replace. Do a search on this forum for the same.
JeffMc202
May 6, 2009 08:52 AM
84FB351
Offroad & 4x4
Oct 16, 2008 07:01 PM
fordolet man
Oct 25, 2007 04:24 PM
77hiboyboy
Jul 2, 2007 02:45 PM
