Shifter
Old Jan 12, 2004 | 04:04 PM
wickymustang's Avatar
wickymustang
Shifter
I have a 1995 F150 5spd. The shifter **** is beat up and the stick has half the paint missing from being rubbed while driving, anybody know where I can get a diff shift **** and what to do with the stick?
Old Jan 13, 2004 | 01:04 PM
frdtrkman's Avatar
frdtrkman
YOU CAN GET A SHIFTER **** JUST ABOUT ANYWHERE. I GOT ONE THAT IS CHROME WITH BLUE LED LIGHTS ON THE TOP. AS FAR AS THE SHIFTER ITSELF, PAINT IT. I DID.
Old Jan 13, 2004 | 05:56 PM
FordMan94's Avatar
FordMan94
hey wickymustang,
i have a '94 5spd that i'm about to out a 5.0 in. lookin at adding a hurst billet plus shifter at the same time. they go for around $200. i posted a a question in the aftermarket forum to see if anyone had it and how they liked it. nice chrome shaft and black ****. you can find them in the summit catalogue if your interested.
Old Jan 13, 2004 | 07:01 PM
wickymustang
Frdtrkman, where did you get the ****? How do I get the old one off, and how did you paint your stick?
Old Jan 14, 2004 | 09:39 AM
frdtrkman's Avatar
frdtrkman
i got it at target for $20. they can also be found on ebay. the shifter **** is pressed on, pull hard and twist a little and it will come off. as for the shifter take off the boot and take out the stud. there is a nut on the stud. take it off and put it on the other side of the stud and tighten. this will pull the stud out. the stud if pressed in not threaded. once the stud is out paint.
Old Jan 15, 2004 | 06:56 PM
wickymustang
At target? Where are you looking? How does the boot come off and what paint type did you use?
Old Jan 16, 2004 | 09:37 AM
frdtrkman's Avatar
frdtrkman
in the automotive dept. you can also go to wal-mart, pep boys or autozone. there are four screws in the plastic ring at the base of the boot, lift the corners of the boot and you will find them. i used plasti-kote paint which you can find at any auto parts store. they are base coat / clear coat so get the color you want and the clear coat.
Old Jan 16, 2004 | 02:42 PM
wickymustang
kool, thanks frdtrkman
ken 01
2004 - 2008 F150
Jan 15, 2011 11:22 PM
Saz221
Jun 21, 2010 08:45 PM
tombell
Dec 2, 2000 10:35 AM
