91 ranger someone help
Old Jan 11, 2004 | 01:28 PM
pman26's Avatar
pman26
91 ranger 2.3 5speed
getting no spark no fuel can hear fuel pump replaced broken crank sensor any way to set ceank sensor?
Old Jan 11, 2004 | 01:47 PM
pman26's Avatar
pman26
crank sensor
91 ranger 2.3 5 speed anyone know how to set a crank sensor?
Old Jan 11, 2004 | 03:59 PM
el conquistador's Avatar
el conquistador
yes... if it is a new sensor it should have come with the tool. if not see if the auto parts store has the positioning tool for it. if they don't then youll have to set it and turn the crank VERY SLOWLY by handle to see if the inner/outer vanes are hitting it. BE VERY CAREFUL. adjust accordingly. then shine a light under the sensor and stand over the battery and look down at the sensor and turn the crank to viually check the setting. the light should shine above and below the inner and outer vanes all the way around.
Old Jan 11, 2004 | 06:32 PM
pman26's Avatar
pman26
crank sensor
adjusted with tool but truck will still not get fuel or spark can hear fuel pump
Old Jan 11, 2004 | 08:38 PM
el conquistador
maybe you forgot to plug something in
Old Jan 12, 2004 | 03:57 PM
pman26's Avatar
pman26
Unhappy 91 ranger someone help
91 ranger 2.3 stalled while driving cranks but no spark or fuel can hear fuel pump replaced crank sensor module, coils but still nothing even replaced eec still nothing found crank sensor broke thats why i changed it timing is also good someone plaese help im going crazy!
Old Jan 12, 2004 | 04:49 PM
el conquistador
I would work backwards and see if you may have missed something. r the coil packs plugged in?
Old Jan 12, 2004 | 05:32 PM
pman26's Avatar
pman26
ranger
everything plugged in found relays all good i think the crank sensor is not working but i have replaced it twice
Old Jan 12, 2004 | 10:45 PM
el conquistador
are both plugs on the sensor plugged in? did you use dielectric grease? Did you rewire the plug (you had to take it off to get it behind the inner time cover correct?) correctly? everything secure?maybe you have a bad wire somewhere?
Old Jan 12, 2004 | 10:51 PM
el conquistador
how did the sensor break anyway? the cause may give you a clue.
Old Jan 12, 2004 | 10:52 PM
el conquistador
did you check the timing belt
