Sponsored by: Real Truck
MPG
Old Aug 9, 2002 | 06:56 PM
MADDG's Avatar
MADDG
MPG
The first tank I checked was at 1300 miles, and I drove alot of stop and go, pulled the trailer for the first time, and then the super slab to work. I got 11.65 mpg. The next tank at 1560 miles, back and forth to work on that same super slab, 14.21 mpg. If this keeps up I'll be very happy. One or two more mpg would be heaven. F-250 Super Cab---V-10--3.73---automatic. WHAT A TRUCK
Old Aug 9, 2002 | 09:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
MPG
Sounds great! Just wait till it gets broken in!
4x4x4x4's Avatar
4x4x4x4
MPG
In spite of many presume the V-10 does suprisingly well if you don't run it for all it's worth.
Old Aug 9, 2002 | 10:16 PM
GORSTEP's Avatar
GORSTEP
MPG
[updated:LAST EDITED ON 09-Aug-02 AT 11:20 PM (EST)] You don't meen 1500 miles per tank full do you? :-X23 The most I ever got was 444 kms (275 miles)and the tank was almost dry!
Old Aug 9, 2002 | 10:43 PM
NoMo's Avatar
NoMo
MPG
Wow, that's pretty bad MPG Gorstep. Although mine is just SRW, it is a 4x4 and I get about 400 miles (not Km) on a tank. And I sure don't drive it "easy".
Old Aug 10, 2002 | 12:45 PM
GORSTEP's Avatar
GORSTEP
MPG
I don't know. It works out to an even 10 mpg. I haul my truck camper, 897 kgs (1960 lbs) plus stuff for two weeks for four, water, propane so closer to 3000lbs and 8'4" wide, 99.9% of the time and usually run around 60 to 70 mph(75 if I can). Lots of mountainous driving, passing uphill etc. etc. 10's better than 9 I was getting with my 460 and this truck is way more fun to drive. My tank holds 140l or 30 imp gallons.
Old Aug 10, 2002 | 10:26 PM
nafzimo's Avatar
nafzimo
MPG
What may be confusing things here is the different tank sizes. My long bed has a 38 gallon tank, a short bed only has a 29 gallon tank.
While we are on the mileage topic, I was wondering... now that the temp here in the midwest has cooled down into the 80's, do you get better mileage with the windows down and the A/C off or with the windows up (less drag) and the A/C on? Maybe one of you guys with the handy little computer thingy could do an experiment or something.
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige Clearcoat Metalic, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control
Old Aug 11, 2002 | 12:49 AM
redranger1's Avatar
redranger1
MPG
you v10 boys and great gas mileage. i think you dont know how to figure mileage. that er yuns are all out to make us v8 boys regret gettin a v8.
-nathan
Old Aug 11, 2002 | 08:13 AM
daimon1054's Avatar
daimon1054
MPG
v10's are not that bad on gas and I would guess better than a v8 while towin. I know I get better milage towing with my V10 than I did with my PSD.
Old Aug 11, 2002 | 10:36 AM
GORSTEP's Avatar
GORSTEP
MPG
Mines a long box and holds 130 l, 28 imp gallons or 32 US gallons!
Just figured my milage out for my holiday (1800 miles of moutainous highway drivin) and got a solid 10 mpg average little under 9 was worst and almost 11 best. I seldom (almost never) use OD and do my best to get were I'm going in a timely fashion, race mini brains(aka vans) up the passing lane and try to be out front of the pack as much as possible.
I guess if I used the smaller gallon to do my calculations my milage would be some what worse. Its kinda like the government trying to balance the books, You use whatever numbers look best.
Old Aug 11, 2002 | 05:17 PM
Outpost22's Avatar
Outpost22
MPG
Your mileage almost reflects mine exactly. Mines a 4x4 and broken in with 18K miles. Is yours 2wd? It will improve mpg after 5000 miles of break-in time.
Old Aug 11, 2002 | 07:49 PM
MADDG's Avatar
MADDG
MPG
My truck is an 02 -- Super Cab---8ft bed---V10---3.73 L/S---XLT---and the other usual goodies, EXCEPT----It also has a Leer---122 camper shell. It is the big wedge shaped shell. I pull a 22ft---8 1/2ftwide cargo trailer with L/Q. That camper shell pushes the air right over the trailer. [I hope so. I have looked and looked at that air lift and it looks perfect.] We will know this coming week-end. We are pulling to the motorcycle rally in Lawton OK. We do a little vending at events like this. I will report on the MPG and IF the air lift is PERFECT. The trailer weighs about 9K with the Harley and vending supplies. WHAT A TRUCK
Old Aug 12, 2002 | 05:36 AM
chuckwpb's Avatar
chuckwpb
MPG
I've been tracking mine since I got it with 6K miles. I now have 30K. You can see the New England temperature swings in the data. I get a solid 12 mpg in the Summer with the AC on and 11 in the coldest part of winter. It took a good 10K miles to wear-in.
I can live with an average of 11.6!
Chuck
Too bad excel chart won't show...
date gal miles mpg
15-Nov-00 23.366 276 11.8
28-Nov-00 27.147 283 10.4
05-Dec-00 27.076 306 11.3
11-Dec-00 25.623 276 10.8
29-Dec-00 24.706 208 8.4
06-Jan-01 22.798 234 10.3
12-Jan-01 26.89 272 10.1
19-Jan-01 23.439 252 10.8
26-Jan-01 26.019 261 10.0
01-Feb-01 25.64 305 11.9
08-Feb-01 25.963 261.2 10.1
15-Feb-01 23.73 268 11.3
20-Feb-01 26.137 276 10.6
02-Mar-01 28.062 288 10.3
09-Mar-01 22.127 257 11.6
15-Mar-01 25.02 273 10.9
20-Mar-01 25.017 301 12.0
29-Mar-01 24.371 294 12.1
06-Apr-01 26.441 302 11.4
12-Apr-01 24.086 296 12.3
17-Apr-01 25.015 300 12.0
24-Apr-01 23.512 271 11.5
02-May-01 26.03 290 11.1
09-May-01 24.732 316 12.8
18-May-01 26.14 319 12.2
24-May-01 26.98 343 12.7
01-Jun-01 26.268 309 11.8
08-Jun-01 23.07 290 12.6
17-Jun-01 26.692 319 12.0
27-Jun-01 25.867 330 12.8
16-Jul-01 26.195 291 11.1
25-Jul-01 25.014 328 13.1
02-Aug-01 26.398 330 12.5
10-Aug-01 26.015 304 11.7
20-Aug-01 23.534 291 12.4
23-Aug-01 17.24 196 11.4
01-Sep-01 23.876 280 11.7
09-Sep-01 20.012 243 12.1
14-Sep-01 19.41 220 11.3
21-Sep-01 27.314 339 12.4
29-Sep-01 25.015 300 12.0
06-Oct-01 21.079 261 12.4
15-Oct-01 27.381 312 11.4
21-Oct-01 21.28 269 12.6
27-Oct-01 27.754 310 11.2
03-Nov-01 25.747 273 10.6
19-Nov-01 43.672 507 11.6
27-Nov-01 26.807 303 11.3
06-Dec-01 20.109 247 12.3
13-Dec-01 24.998 260 10.4
18-Dec-01 25.494 301 11.8
02-Jan-02 23.312 236 10.1
15-Jan-02 35.83 379 10.6
20-Jan-02 24.115 252 10.4
26-Jan-02 24.462 285 11.7
30-Jan-02 24.257 325 13.4
07-Feb-02 26.293 279 10.6
13-Feb-02 28.835 351 12.2
22-Feb-02 26.385 281 10.6
01-Mar-02 26.75 295 11.0
07-Mar-02 19.79 255 12.9
14-Mar-02 24.432 276 11.3
22-Mar-02 26.577 294 11.1
04-Apr-02 27.194 293 10.8
10-Apr-02 21.303 265 12.4
27-Apr-02 32.706 373 11.4
04-May-02 19.344 226 11.7
06-May-02 9.371 146 15.6
10-May-02 16.357 190 11.6
19-May-02 23.949 289 12.1
24-May-02 25.014 298 11.9
31-May-02 24.875 293 11.8
07-Jun-02 24.482 286 11.7
17-Jun-02 31.048 397 12.8
26-Jun-02 25.979 308 11.9
03-Jul-02 23.921 291 12.2
08-Jul-02 23.287 291 12.5
15-Jul-02 25.567 297 11.6
21-Jul-02 19.949 269 13.5
26-Jul-02 25 319 12.8
03-Aug-02 26.409 311 11.8
1999 F250 SD super-cab 6.8l V10 4x4 Auto
Old Aug 12, 2002 | 04:09 PM
robnfl's Avatar
robnfl
MPG
Well, I've got one of those computer thingys and on flat level (FL duh!) roads I get the following readings:
60mph - 23mpg
65mph - 22mpg
70mph - 21mpg
and...
50mph - 28mpg
These are all unloaded with just the A.R.E. topper and of course with the AC cranking. Mileage is 3,300 miles.
During normal driving back and forth to work which is about 6 miles highway and 7 miles stop-and-go I am getting 19mpg.
When towing a 5,000# trailer: (ac cranking/1,500 miles on the truck)
60mph - 13mpg
65mph - 11.5mpg
70mph - 10.5mpg
Hopefully, the towing fuel economy will increase after the PSD is broken in.
Needless to say that the fuel economy is far better than my '00 expy/4x4/5.4, which was lucky to see 13mpg around town and 17mpg on the highway.
Well...all I have to say is...the PSD RULES!
Old Aug 12, 2002 | 05:49 PM
rplett's Avatar
rplett
MPG
My numbers are just a bit lower unloaded. By about 1 mpg at all speeds. Your towing figures are a lot lower than mine though. I get about 15-16mpg at 70mph with a 3500lb trailer. Does the extra 1500lb really make that much difference?
rwp
'97 PSD 3.55 5sp.
