460 Sometimes doesn't start?
Old Jan 12, 2004 | 11:18 AM
Cparker340's Avatar
Cparker340
I have an 87 f250 460 and to start it I pump the gas once and she fires right up. Then when I go to restart it, the engines turns over but doesn't start. I put in new plugs and a new coil. It seems to be fine then it starts acting up. The distributor is the original 300k miles. Could this be the problem. New idiot box too.
Old Jan 12, 2004 | 07:45 PM
RichardMaerz69's Avatar
RichardMaerz69
does it only act up when it warms up.? If it does it could be the idiot box, I've heard of people getting a bad box.I'd get it checked anyway,good luck
Old Jan 13, 2004 | 01:58 PM
Mush's Avatar
Mush
Check the coil connections,if it is a slide on clip, make sure it is on all the way.On mine I had to really push hard to get it on.
Old Jan 13, 2004 | 11:32 PM
FordPickup460's Avatar
FordPickup460
Could it be flooding somehow ? Dont step on the gas to restart it when its warm.
Old Jun 8, 2004 | 12:40 PM
Cparker340's Avatar
Cparker340
It doesn't start the first time you turn it over. You have to pump the gas to get it to start. Once it is warm it fires up right away.
