1985 Ranger 2.3L
Old Jan 12, 2004 | 08:45 AM
falcontom's Avatar
falcontom
1985 Ranger 2.3L
Hi, great site. I have a 1985 Ranger 2.3L (1st year, I believe)for fuel injection. Problem is I smell a faint gas smell in the comming from engine compartment with no vosable leaks. Seems to be the same either with or with the motor running. Thanks for any help.
Old Jan 12, 2004 | 02:56 PM
thesaintoc's Avatar
thesaintoc
Check for cracks in the rubber hoses to the evaporative canister and smell around there is the cheap way. The expensive way is to call around to see if a garage will turn on thier smog machine to poke around under the hood with the tail pipe probe, to try and locate the leak. Look under the drivers side and see if the fuel pump or fuel filter canister is leaking. The plastic fuel lines on this vehicle work great untill someone plays rough and/or does not repair a defective line.
nascarts
Jan 31, 2006 02:17 PM
nascarnc
Nov 15, 2005 06:03 PM
Smurf-Slayer
Mar 12, 2005 09:04 PM
Scorpion25
Oct 29, 2004 11:00 PM
btfast
4 Cylinder Engines
Jan 21, 2004 09:55 AM
