302 Not Running When Cold
Old Jan 11, 2004 | 10:39 PM
Cybertaz126's Avatar
Cybertaz126
Question 302 Not Running When Cold
Old Jan 12, 2004 | 07:05 AM
EPNCSU2006's Avatar
EPNCSU2006
Pull the codes to see if any faults are listed. You can check the resisitance of the air charge temperature sensor to see if it is within spec.
Old Jan 12, 2004 | 12:35 PM
bdonalds's Avatar
bdonalds
Sounds like it could be a lot of things. Is it missing? I had the same idle problem when I lost compression in one cylinder due to a bent valve.
Old Jan 12, 2004 | 09:34 PM
Cybertaz126
Grk1970
May 29, 2018 10:31 AM
lawrenceleblanc
May 16, 2015 09:48 PM
tomfoolery
Dec 5, 2014 09:41 AM
prauch007
Feb 9, 2005 10:12 PM
Olprospecter
Aerostar
Feb 26, 2003 10:41 AM
