1978 - 1996 Big Bronco
fuel pump problems
Old Jan 11, 2004 | 12:41 PM
Jtanner76's Avatar
Jtanner76
fuel pump problems
I have dropeed my gas tank countless times fixig fuel pump problems. changed it twice, now the plug is broke. (truck runs out of gas a lot now. LOL.
I was wondering if i could just place a inline pump somewhere on the chasis and totally bypass the in tank one.
anyone with this experience
Old Jan 11, 2004 | 02:12 PM
Jtanner76's Avatar
Jtanner76
only getting 30-35 psi, just checked. truck is fuel injected
Old Jan 13, 2004 | 09:34 AM
bronco up's Avatar
bronco up
If Im not mistaking there is a low pressure in the tank and a high pressure in the frame rail under the driver door. The pressure sounds right but maybe getting ready to go out if the pressure is going up and down under a load.
Old Jan 13, 2004 | 09:51 AM
ALSAIR's Avatar
ALSAIR
It may not be a fuel pump problem at all! Have you checked the fuel pump relay's, or just even replaced them? Is it the low pressure pump or the high pressure pump under the drivers seat on the frame rail. 40 P.S.I. is normal pressure. Have you changed the fuel filter when you changed the pump. A faulty relay could being causing the pump to fail! Are the supply or return lines kinked? Is the vent line for the tank in good shape. The plug may have been the problem from day one with a poor connection causing overheat condition on the pump. You need the low pressure pump to prime the system, it is that hummmmmming sound you here just before you turn the key to start the motor.
If it ends up being the pump again there is a reason, and I would try to find it, cause replacing that pump is a pain in the *** and expensive. Especially if you got a full tank of gas!!!
She Ain't Revved Ti'll The Rods Are Thrown!
Al
fordf1501991
19
May 30, 2019 06:32 PM
tip49
13
Mar 15, 2017 10:52 PM
Krose788
Aug 17, 2016 10:47 PM
tom42nm
May 11, 2012 09:04 AM
87f150xlt
15
Nov 9, 2004 12:19 AM
