Cant Get To Bulb
Old Jan 11, 2004 | 11:12 AM
81's Avatar
81
Cant Get To Bulb
I have '92 F-150.Trying to change burnt out marker bulb on drivers side.Its the one on top beside the headlight.The only way to access it is thru small round hole.Its too small for a even a child to get his hand in to get out.Tried needle nose and its just too cramped.Does this plug twist out in case i do manage to get a handle on it?Any ideas appreciated.
Old Jan 11, 2004 | 12:01 PM
acerockola77's Avatar
acerockola77
This should be able to help you: https://www.ford-trucks.com/forum/sh...ad.php?t=10070
Old Jan 11, 2004 | 02:35 PM
81's Avatar
81
Thanks man..Guess thats the only way.
Old Jan 11, 2004 | 03:47 PM
acerockola77
Unless you can find someone with real small hands to help you.
Old Jan 11, 2004 | 10:04 PM
bigric's Avatar
bigric
I took out my battery and washer/coolant reservoir and gently used my long needle-nose pliers to swap them out. It didn't take very long at all, and it was a lot easier than I thought it would be.
Old Jan 12, 2004 | 07:56 AM
81's Avatar
81
bigric:the plug/bulb twist out counterclockwise right?
Old Jan 12, 2004 | 03:05 PM
bigric's Avatar
bigric
I believe that they were counterclockwise to remove. Turn them about 1/8 or so and then pull them out.
