really bad starting problems!!!
Old Jan 10, 2004 | 06:19 PM
boogity24's Avatar
boogity24
the other day i ran out of gas, and when i went to try to crank it up, i turned the key off and it kept cranking, and it kept doing it until it burned the silinoid out. and sometimes the engine wont shut off after i drive it, and i try to dump the clutch and nothing happens even when i am in gear!! someone please help me figure this out!?!?!?
Old Jan 10, 2004 | 07:18 PM
lee's Avatar
lee
Hi,
Did a new solinoid cure the cranking problem? My ole 79 1/2 ton did that a few times and a new solinoid fixed it.
I am not clear on your other problem of not being able to shut the truck off. Do you mean it continues running by dieseling?
Take care,
Old Jan 10, 2004 | 07:21 PM
Faithful Old Road Dog's Avatar
If you ever run dry again, before you crank it, pour some gas down the carb. Not too much or you'll flood it. About the amount you'll need to fill an antifreeze cap should do. Have you changed the solenoid? Dumping the clutch will work if your engine is dieseling. If you haven't changed the solenoid, check the wires connected to it. They may have gotten hot and fused together.
Old Jan 10, 2004 | 07:25 PM
boogity24's Avatar
boogity24
oh yeah, i changed the solenoid because half of it melted. but that fixed my starting problem, but the 2nd problem happens maybe once every 2 months.
Old Jan 10, 2004 | 08:09 PM
willowbilly3's Avatar
willowbilly3
It may be your ignition switch. I have had them wear out and do strang things intermittantly.
Old Jan 10, 2004 | 09:04 PM
boogity24's Avatar
boogity24
yeah maybe, but it isnt bad enough to fix......yet
Old Jan 11, 2004 | 11:16 AM
oldiron's Avatar
oldiron
Low voltage
Low battery voltage or a poor ground will cause the same situation. Check your ground connections especially the block to firewall. You don't want the truck to fire up while this is going on, the starter will likely stay engage on the running ring gear and chew it up.
Greg
Old Jan 11, 2004 | 11:32 AM
boogity24's Avatar
boogity24
i had a dream last nite that it was doing the same thing and woke up this morning and hurried up and made sure it was crankin rite. whew!!, but i think it was the solenoid, we have about 5 of them laying around the yard so im glad i had a spare.
