1978 - 1996 Big Bronco
Clutch Problem
Old Jan 10, 2004 | 03:48 PM
dyarumian's Avatar
dyarumian
Question Clutch Problem
I have a '96 with the 5.0 and 5 speed tranny, yesterday it barely got above 0 degres outside, now it wont shift into gear, and the clutch pedel wont come all the way back after i push it down. The only way to get it in gear it to pump the clutch 20+ times. SOmething must be wrong with the clutch system. Hayes says to bleed the system but sence its so cold out i can barely get any fluid out of the bleeder valve. Do i realy have air in the fluid or is it just to darn cold? .
Old Jan 10, 2004 | 03:53 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Well, hydrolic fluid doesent freeze, if hydrolic fluid froze, it would be too cold for you, or the engine would not even turn over.
Maybe check and see if the resivior is full, or you might just have to bite the bullet and get under there and bleed the system.
