pulls to the right
Old Jan 10, 2004 | 12:02 PM
jashforth's Avatar
jashforth
pulls to the right
hello i have a 1982 f-150 and a1993 f-150 thy both pull to the rite when i brake the 1982 started slowly and the 1993 started after i put new pads on it i dont now where to start
Old Jan 10, 2004 | 12:54 PM
Beast12's Avatar
Beast12
Your calipers could be seized....causing them to brake to one side. When you changed the pads, did the one side look different than the other side.....the pads i mean. Or maybe you didn't bleed the lines correctly. And maybe only one side is braking. Just some ideas.
-Matt
Old Jan 10, 2004 | 03:45 PM
Franklin2's Avatar
Franklin2
-Matt
I have seen this happen often. The pistons in the calipers are extended way out because of the thinner worn pads. Rust can form behind the piston, and when you use a c-clamp to push the piston back so the new pads will fit, the piston slides into the rust and gets stuck. The solution is to get rebuilt calipers. They are cheap. Also make sure you clean and use HIGH temp grease on the slides where the caliper mounts. The caliper only has a piston on one side, so the caliper housing has to slide for the other pad to work.
The only other thing that seems to happen (rarely) is the brake hose will disentegrate on the inside, causing the fluid not to pass very well from the master cylinder to the caliper.
