changing gear lube
Old Jan 10, 2004 | 09:23 AM
jakemarty90's Avatar
jakemarty90
changing gear lube
I want to change to gear lube in the front and rear axles of 95 4x4 I6 M5spd. On the rear, I assume you remove the back housing plate to drain the oil but I can't see how to drain the front axle. How do I do this? Do you pump it out of the fill hole?
Old Jan 10, 2004 | 04:14 PM
Lou Braun's Avatar
Lou Braun
You are right. Just pump the oil from the front axle carrier housing fill hole and replace it with a fresh batch. That housing is disassembled only when both front axles are removed.
Lou Braun
