Sponsored by: Kumho
Replacing brake lines.
Old Jan 10, 2004 | 03:22 AM
Dayle's Avatar
Dayle
I have a 1993 F-150 that has a hole in the rear brake line. I am replacing the lines form the proportioning valve in the front to the point that the line goes through the frame by the rear tank. I got the front loose quite easily but the rear is giving me some trouble. I tried cuting the line at the connector and placing a socket over the connector but I all i have succeded in doing is rounding this one off. I was wondering if any one had any suggestion on removing this, and if this is a different type of connector?
Thanks For your help
Dayle
Old Jan 10, 2004 | 08:59 AM
ajstephan's Avatar
ajstephan
I just replaced the brake lines on my '68 Scout and I had a lot of problems removing those fittings that have been on for 35 years until I started using a flare wrench to remove the line nuts. However, if you're using a socket and it is still rounding then you probably have the wrong size of socket. Well, also the metal is quite soft. Nevertheless, confirm with a metric or standard. Either way, it sounds like you'll have to get out the file and try to get those edges sharp again, so the original size is irrelevant now.
To loosen it up, make sure you use lots of liquid wrench/PB Blaster, etc. to loosen up the connection and let it work it's way in for a while. If that doesn't work, heat always makes a big difference. Put a hair dryer or something similar (that won't cause a fire with the penetraing oil!) to heat the fitting. That's about the only use I have for my hair dryer these days!
Good luck!
Old Jan 10, 2004 | 11:36 AM
MustangGT221's Avatar
MustangGT221
hair drier probably won't give enough heat. Those small handheld torches work great for these.
Old Jan 10, 2004 | 02:46 PM
Dayle's Avatar
Dayle
Thanks guys.
I finally got it out today. I heated it up with a handheld propane torch and was able to get a pair of vice gripes with some teeth on it enough to get it out.
Old Feb 9, 2004 | 09:34 PM
maa139's Avatar
maa139
Similar question. I'm replacing the front brake lines. I have everything all set to go, but have one question. In the haynes manual, it says to plug the brake line after it you remove it so that the brake fluid won't all leak out. What do you plug it with?
Old Feb 10, 2004 | 10:37 AM
rebocardo's Avatar
rebocardo
I do not plug it, I cap it with a vacuum cap and small clamp. This way you cut down on air in the line. Though I do let all the fluid out when I bleed it, so all the fluid is new.
