Tranny Probs - Astro Van
On the phone, he mentioned that he had a slight tranny leak & that the tranny was slipping. Told him to check the tranny fluid & that sometimes that slipping is due to bands that need tightening.
He put some stop leak in there & added tranny fluid, thinking that it needed more fluid, but instead, ended up adding too much fluid & both front & rear seals blew out.
He's going to pull the tranny & change out the seals, but we'd like to know if that's the only damage that could have happened by adding too much fluid ?
Also, what might be the most likely cause & cure of the "slipping" problem ?
Thanx in advance...
>> There is no band adjustment on a 700R4. <<
>> I doubt the seals blew from being overfilled. Usually, it will just blow fluid out the vent. The stop leak most likely turned the seals to jelly and that's why they failed. This is very common. There are also dozens of internal seals in that transmission that have very likely suffered the same fate. I boubt the tranny will work for very long, even with new front and rear seals. <<
>> Over filling an automatic usually only results in airating the fluid (whipping it into a foam). This willl make the tranny slip just like getting air in your brake lines will cause you to loose braking. <<
Steve
He's discouraged, but able to come to terms with the reality & he'll push thru this one & onto better days. At this point, because he can't afford to buy another vehicle at present & needs transportation for work, I think he's going to replace the seals & try to keep it operable long enough to give him time to either save up for something else, or to go with a used tranny if need be.
No easy solutions for this one, but he'll make the best of it. Thanx again very much...
No offense intended, archangel, but it's the same tranny. Folks here have been very helpful & that's much appreciated. In this day & age of uncertainty, along with our economy being moved overseas & leaving many Americans jobless, just seems like some things (the age-old rivalry of Ford vs. Chevy) might be overlooked in favor of Americans being helpful & understanding of one another. Another way of looking at it would be for you to be flatterred that someone with a Chevy was asking Ford devotees for their experienced advice.
As what?
The 700R4 is a GM trans only.
I dont remember seeing it in any fords, and if I did I would be greatly amazed!
I agree with the helping other idea but have had subjects locked out before for talking to someone "Chevy" here.
One responder was kind enough to offer the 700R4 designation, I showed the response to my son & he said that's the same tranny as his.
I was merely trying to help my 18 yr. old son get his truck back on the road so that he could get to work. It's encouraging to see someone of his age try to earn an honest living rather than take the route that many others of his age group have chosen & I'll do what I can to keep encouraging him in his pursuits.
That's unfortunate that you had a thread closed due to mention of "Chevy". It would seem that helping others would be the priority, even if it meant an occasional bending of the "rules".
