Oil Pan Baffle
Old Jan 9, 2004 | 02:32 PM
kyyates's Avatar
kyyates
Smile Oil Pan Baffle
I HAVE A 54 F 100 WITH A 239 ENGINE. THE OIL PAN DOES NOT HAVE A BAFFLE IN IT, AND I WOULD LIKE TO CHANGE TO ONE THAT DOES HAVE A BAFFLE. WHAT YEAR ENGINE WILL I NEED TO DO THIS? THE REASON IS THAT WHEN I STOP REAL QUICK THE OIL PRESSURE GOES TO NEAR ZERO. THEN COMES BACK TO NORMAL IN ABOUT 2 SECONDS
Old Jan 9, 2004 | 11:42 PM
My58Ford's Avatar
My58Ford
You can modify your existing pan by simply welding a baffle into it.
Old Jan 10, 2004 | 06:07 AM
kyyates's Avatar
kyyates
Smile oil pan baffle
if i weld a baffle do i weld it in horizonal or vertical?
Old Jan 10, 2004 | 05:08 PM
My58Ford's Avatar
My58Ford
The few y block pans I've ever seen with baffles been horizontal, but you might want to get an opinion from an engine builder or mechanic beforehand to figure the best way to do it.
Old Jan 10, 2004 | 05:15 PM
onelowzuki's Avatar
onelowzuki
All the pans i have ever seen was horizontal also, but i have never seen a y block pan though.
austint513
6.7L Power Stroke Diesel
40
Jan 17, 2014 07:32 PM
cbass139
Jul 26, 2012 06:07 AM
LFDavidson
Nov 19, 2010 06:40 AM
73FOMO
Nov 14, 2006 04:18 PM
BORG
Bronco II
13
Aug 3, 2003 06:51 PM
