Engine turns off AFTER I get out...
Old Jan 9, 2004 | 09:06 AM
txwing's Avatar
txwing
Exclamation Engine turns off AFTER I get out...
When I bought my truck, ('71 f-100, 300-6, 3 on tree) the lady mentioned that sometimes when she would turn off the truck, that the engine would keep running for a few seconds before it shuts off. (& jump like a horsey)
And now that I finally got my truck working, I noticed she's right.
What would cause this? How can I fix this?
It doesn't happen every time I turn the truck off, but i'm starting to get embarrassed when it does it at work.
Please help.
Old Jan 9, 2004 | 09:12 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
It sounds like to me....its either in the timing? or the engine is running hot? Hope you fint it...
Old Jan 9, 2004 | 10:24 AM
BB's Avatar
BB
It's dieseling, very bad for an engine. Try turning down your idle speed and when it does it, dump the clutch.
Old Jan 9, 2004 | 10:27 AM
billemc's Avatar
billemc
Put a slight load on the engine as you turn off the ignition. If it were an automatic, you could just shut it off before putting it in park. Try it...
Old Jan 9, 2004 | 10:30 AM
idealtrucks's Avatar
idealtrucks
Sounds like you just need your timing adjusted to me
Old Jan 9, 2004 | 10:52 AM
txwing's Avatar
txwing
Man, I really appreciate all of your comments!
I LOVE this site!
BB... what's up with the Bill Murry photo? : )
(Hallarious)
Old Jan 9, 2004 | 11:32 AM
gedteach's Avatar
gedteach
Sometimes carbon builds on the pistons causing hot spots which will ignite unspent gas in the combustion chamber. The solution is clean the piston tops. I would try the easiest and cheapest methods first. TC
Old Jan 9, 2004 | 12:22 PM
Faithful Old Road Dog's Avatar
Be aware that if you do dump the clutch, you might get a backfire through the pipes. It could blow out your muffler.
Old Jan 10, 2004 | 02:17 PM
BB's Avatar
BB
(Hallarious)
There was a discussion a while ago in the GC forum about getting rid of gophers and... well... you know where I was going with it.
Barry
Old Jan 10, 2004 | 08:13 PM
bigric's Avatar
bigric
Like they said, retard your timing. Your carb may need rebuilding as well. Check your plugs for excessive buildup. Do NOT let it continue dieseling.
Old Jan 10, 2004 | 08:24 PM
willowbilly3's Avatar
willowbilly3
95% of the time an engine tends to run on is because the curb idle is too high. I would almost bet if you set the idle to factory specs it will quit dieseling or run-on. Carbon or hot spots could cause it but that is much less likely. If the timing was causing it, then it would have to be out far enough that it was running poorly.
Old Jan 12, 2004 | 08:04 AM
txwing's Avatar
txwing
I spoke to a mechanic friend yesterday and he believes that it's the carb idle too high. I didin't get a chance to work on the truck over the weekend but I'll try tonight.
BTW
The truck runs good and it's a new carb, but a few months ago I had aother problem and a few guys & I messed with the screws on the carb. Also, when the truck is running it smells too much like gas.
I'll keep you all posted on the progress.
Thanks,
TA
Old Jan 12, 2004 | 08:09 AM
texan69ranger's Avatar
texan69ranger
i have been having the same thing with my truck for quite a while, i thought it was something bad, and my dad had said that it was dieseling and there was nothing wrong with it, i couldnt fix it, and it didnt hurt my motor, my idel is good, i havent checked my timeing, but it is EXETREMELY embaressing, i havent done the clutch dump yet but i did one time take it up to about 1500 and turned it off, and it made quite of a show with flames and loud back fires
Old Jan 13, 2004 | 07:30 AM
texan69ranger
if you have a stick, then putting a slight load before turning it off works great, i did it yesterday, i just let off the clutch a little, and it turned off perfect
Old Jan 13, 2004 | 08:12 AM
txwing's Avatar
txwing
Well I adjusted the carb and it seems to turn off fine. (at least last night & this morning).
TEXAN69RANGER, I don't know, but I don't think that "dieseling" can be good. Either way, I feel for you brother! : )
