Bronco II Ford Bronco II
Help Please
Old Jan 9, 2004 | 04:21 AM
Louiscypher's Avatar
Louiscypher
Help Please
Hi Newbie here, I own a 1988 Ford Bronco II 2.9 liter, and the fuel line with connector melted because it was so close to the exhaust. THe problem is they dont make this part anymore at Ford. Does anyone have any suggestions? I need my car and I live in San Francisco. Has anyone else have that happen to them? I need to find replacement for it quick. Thanks for any info.
Old Jan 9, 2004 | 01:18 PM
Stanstruck's Avatar
Stanstruck
Check your local junkyards or find a parts truck in your local paper. If this doesn't work check back here.
Stan
Old Jan 9, 2004 | 02:23 PM
Louiscypher
Thanks Stan, I have tried all the local places but will need to go to the junkyards, but until then i need my car so im sort of in dire needs. Thanks for ur help. peace
Old Jan 9, 2004 | 08:59 PM
MJB's Avatar
MJB
If the line your talking about has the quick disconnects you can always cut the bad part of the line out then splice in a new gas hose. Make sure it's a gas hose. Double clamp on each end. There's 40 PSI of fuel pressure there so make sure you do it right.
Old Jan 9, 2004 | 10:09 PM
Louiscypher
No unfortunately its the plastic clip that is at a 90 degree angle that melted down becuase of its location. Cant find a adapter for it either. Its a plastic clip on both ends with fuelline about 4 ft 1/4 inch in diameter. Ive asked several ford and auto supply ppl and they said no suck thing as an adapter. The part they gave me is E6t2-9J33. any suggestion is greatly appreciated. thanks
Old Jan 10, 2004 | 06:55 AM
8588ranger's Avatar
8588ranger
Hi,
I breaked my gas line fitting on my 90 Bronco II. Was going to check float on the sending unit cause my gas gauge was not working. Anyway my local parts supply had a Dorman fuel repair
kit. Intructions said soak the gas line in boiling water for 10 seconds, bull. The gas line is made of Nylon and you need a
special tool to install the new fitings on. Read somewhere on the internet that repair line kits leak! What I did was find another
gas line fitting that I needed and carefully heated the Nylon
tubing with a heat gun and carefully cut off the melted gas line. Do not cut the fitting or it might leak. Then I went to my
local Ford dealer and they installed the fitting on for me.
I found a web site in CA that work guy on Mustangs and he has gas lines and fittings for sale but you need the special installation tool.
Also found a company in Canada that makes replacement fittings with different lengths of tubing but you need that special tool.
James V.
dng
Escape & Escape Hybrid
34
Jun 7, 2020 11:57 AM
chevy_lover
May 26, 2019 10:23 PM
Col Flashman
Sep 15, 2013 11:59 PM
99FORD EXPY.
Jan 17, 2013 06:50 AM
fleo411
North Carolina Chapter
Jun 8, 2007 05:24 AM
