Volare ball joint socket
Old Jan 8, 2004 | 01:34 PM
BillR's Avatar
BillR
I am rebuilding volare clip in my 56 F100 big window and need to find a supplier for the ball joint socket needed for removing the screw in type ball joints. I think the correct size is 3/4 by 1 29/32". Does anyone know who supplies this particular socket for less than $50??
Old Jan 8, 2004 | 06:02 PM
fatfenders's Avatar
fatfenders
Big honkin pipe wrench and just a little heat to preserve the threads in the A-arm. The threads like to gall on the removal sometimes. You save forty bucks on a tool you honestly don't need. Large crescent wrench works even better.
Old Jan 8, 2004 | 06:25 PM
BillR's Avatar
BillR
Thanks for the help. I used a 24" crescent wrench on the top ball joint but the clearance was so close that I couldn't get a good bite on it. I did finally get it out but I was hoping for an easier way. You are probably right so maybe I'll just grin an bear it.
Thanks for the reply.
Old Jan 8, 2004 | 06:41 PM
fatfenders's Avatar
fatfenders
There are some non-traditional pipe wrenches that may work better in the tight clearance. I'm not a plumber so I can't recite the names. Still a better investment than a socket that will rot in your tool box.
Old Jan 9, 2004 | 07:18 AM
mikew's Avatar
mikew
I used a pipe wrench also. The problem was that I could only turn it about 10 degrees before hitting the control arm. Took about 2 hours and 4 busted knuckles.
I ended up taking the second one to the machine shop to have them turn it out. It might be the best $10 I've spent.
Mike
Old Jan 9, 2004 | 09:11 AM
cobraguy's Avatar
cobraguy
You can try you local Kragen, Checker, Schucks, or Pep Boys they just may have one to loan or rent. Good luck, Rich.
Old Jan 9, 2004 | 09:54 AM
Okiedokie's Avatar
Okiedokie
I went to a local mechanic I know and ask where to get one. He said "here use mine, I never use it anymore", so I did. Yes I did take it back. Joe
Old Jan 9, 2004 | 10:53 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Had mine done at my local NAPA store and even they didn't have the tool, but they bought one to do my ball joints rather than turn down the job. I didn't do it myself because I didn't want to take a chance screwing up my control arms...and I don't need any more busted knuckles. It was money well spent...
Old Jan 9, 2004 | 12:19 PM
BillR's Avatar
BillR
I scoured the net trying to find a cheap(er) ball joint socket since I have 3 other buddies all installing Volare clips in various rides.
The best deal was a 3/4 by 17/8" for $23. Volare is 3/4 by 1 29/32
(a 32nd to small). My neighbor has a Bridgeport mill and sez he can shave that 32nd off. What the hell, for $23 maybe I'll go for it! Thanks to all for your help and advice. Keep wrenching!!
