water pump replacement
Old Jan 8, 2004 | 01:26 PM
fordtrucklover94's Avatar
fordtrucklover94
Unhappy water pump replacement
I am in the process of replacing my water pump on my 94 ranger 3.0L. I have run into a problem with the ac bracket being in the way of the 11th bolt. We have pulled three bolts out, and the bracket still won't move, is there more bolts there or is there another way to get behind the belt tensioner without taking apart the whole ac/ps assembly. Any help, ASAP would be best.
This is so frustrating, try and do something yourself, and run into a bolt causing a problem
Old Jan 22, 2005 | 01:31 AM
charlie siarra's Avatar
charlie siarra
I find myself with the same problem asking for the same help. I can not remove the water pump on my fantastic 94 Ranger because of the belt tensioner being in the way. Help
Old Jan 22, 2005 | 04:56 PM
el conquistador's Avatar
el conquistador
this is off autozone.com:
3.0L Engine
See Figures 2 and 3
  1. Disconnect the battery ground cable.
  2. Drain the cooling system.
<TABLE cellSpacing=0 cellPadding=0 width=310 border=0><TBODY><TR><TD vAlign=top width=10 colSpan=2 height=10></TD><TD vAlign=top width="100%" height=1></TD><TD vAlign=top width=10 colSpan=2 height=10></TD></TR><TR><TD vAlign=top width=1 bgColor=#8c8c8c height="100%"></TD><TD vAlign=top width=9></TD><TD vAlign=top align=middle width=290><TABLE cellSpacing=0 cellPadding=0 width=290 border=0><TBODY><TR><TD align=middle bgColor=#ffcc00 height=15>CAUTION</TD></TR><TR><TD align=middle></TD></TR><TR><TD>When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. </TD></TR></TBODY></TABLE></TD><TD width=9 height="100%"></TD><TD width=1 bgColor=#8c8c8c height="100%"></TD></TR><TR><TD vAlign=bottom align=left width=10 colSpan=2 height=10></TD><TD vAlign=bottom height=1></TD><TD vAlign=bottom width=10 colSpan=2 height=10></TD></TR></TBODY></TABLE>
  1. Remove the engine fan.
  2. Loosen the 4 water pump pulley bolts.
  3. Remove the accessory drive belts.
  1. Remove the water pump pulley.
  2. Remove the alternator adjusting arm and throttle body brace.
  3. Remove the lower radiator hose.
  4. Disconnect the heater hose at the pump.
  5. Rotate the belt adjuster out of the way.
  6. Remove the water pump attaching bolts. Note their location for installation.
  7. Remove the pump and discard the gasket.
  8. Thoroughly clean the pump and engine mating surfaces.
