Im still stumped on finding the spout. Can i disconnect it by unplugging the gray plug on the fender? Ahh i really need to do this because my truck has been running like a dog.
Well i found a gray circular plug near the master cylinder. It has three wires coming out one of the sides, a yellow wire, yellow/black, and one thats all black. Could this be it?
No; the spout is going to have just 2 wires. If you have the TFI module mounted on the distributor, I think it may be there near the dizzy; I forget on the earlier trucks.
Does anybody have a picture maybe of the 91 and earlier spout connector? I know the general area now but still dunno what to disconnect. Id look at the online Chiltons manual but its down at the moment. Really sorry for all the questions....
>>>>>>warning: if using MAF, dont advance it past spec.<<<<<<
Tell me about this.
I am new to the "newer" Ford trucks and their computer issues.
ok, the 'MAP' or speed density trucks (92 and older) used 2 drivers for the injectors and fired 4 at a time, 4 times each 2 revs -its multiport, its pretty good, but could be better. Around 92 on the lightning and 93-on (I think I have the dates) the truck went to MAF. Pre-96 and OBD2 and a crank position sensor, the spark timing was used to set a base for the injectors because along with MAF came SFI. If you advance (or retard for that matter) then you will affect injector pulse timing.
Originally posted by quaddriver ok, the 'MAP' or speed density trucks (92 and older) used 2 drivers for the injectors and fired 4 at a time, 4 times each 2 revs -its multiport, its pretty good, but could be better. Around 92 on the lightning and 93-on (I think I have the dates) the truck went to MAF. Pre-96 and OBD2 and a crank position sensor, the spark timing was used to set a base for the injectors because along with MAF came SFI. If you advance (or retard for that matter) then you will affect injector pulse timing.
Batch fire fired the 4 injectors once every revolution. First gen lightnings were still speed density, and the first MAF trucks appeared in California I believe in '94. There is no crank position sensor on these trucks. All timing information comes from the distributor, which will affect injector timing to some extent, but not enough to even think about.
I don't think so. If it runs with more power and better fuel economy, leave it where it is. It doesn't affect injector timing enough to even worry about.
MAF didn't come until '95 on most of the engines, so they were still bank-fired until then. Except for the Lightning trucks. Also, MAP does not equal speed density; all of the EFI (even the Power Stroke diesel) vehicles on the road have MAP sensors.
But yeah, don't advance the timing too far unless you really know what you are doing. More advance means higher cylinder temps and leads to detonation.
MAP is the dominant sensor in speed density systems, and they are commonly referred to as a MAP systems. MAF vehicles have a BAP sensor instead of a MAP. There is no difference in the sensors themselves, but the MAP is for manifold vacuum, and the BAP measures ambient air pressure. Lightnings are sequential injection stock?
My timing was set at 15 degrees advanced and I got a lot of pinging from the engine. Once I put it back to 10 degrees all was well. Can someone tell me why my truck would be different from the other guys with 5.0s?
If it runs well with no pinging, I'd leave it. I've always been told to advance it as far as you can without making it ping for best power and economy. I couldn't get more than 12 degrees or so on my truck before it pinged.
